Old 06-24-2004, 07:52 PM   #1
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Default Injector problems
well.. I installed the 370cc injectors today, only to find out my engine will not even turn over...
I turn the key and it trys to start.. and nothing..
So I put the stock ones back in.. same thing happened.. Anyideas?
NeaD is offline   Reply With Quote
Old 06-24-2004, 07:52 PM   #2
NeaD
Member#: 43371
Hydra User, Blue
the 370cc are sidefed and are from the sr20.
Old 06-24-2004, 08:21 PM   #3
Unsung Boxer
Member#: 37196
sure you got the fuel lines hooked up right? All the sensors hooked up?
Are you getting spark? Pull a plug wire off, and set it next to something grounded... then have someeone turn the engine over.
If you are getting spark, then it is not likely a sensor, it is something w/ fuel delivery
If you are not getting spark, you wont get fuel. In this case, it could be a sensor, or coil pack... something limiting spark.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-24-2004, 10:26 PM   #4
NeaD
Member#: 43371
Hydra User, Blue
-Jake
Im not getting spark with the nemisis or the stock ecu. How do i test the coil pack? The wire going to the coilpack shows 12v between the red/blue and yellow/black wires when trying to start.
Old 06-26-2004, 09:32 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
is your crank sensor plugged in?
Do you have test light?
on one of the wires going into the coil pack you should have a pulsed signal while cranking with the test light grounded.
Jay
vf22 + STI injectors = problems? senomar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-28-2004 10:54 PM
ej20g injector problems smacksube Subaru Conversions 4 01-13-2004 03:12 PM
Fuel injector problems LegacyGT Engine Management & Tuning 0 10-04-2003 12:28 AM
Injector Problem?? Suby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-21-2002 08:41 AM
Oh boy...Injector Problems (Tuner people) JenisonWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-27-2002 10:44 PM
