Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 10-18-2000, 09:30 AM   #1
rjones
Member#: 1477
2003 wrx wagon
Post AF vs. EGT
I've seen losts of posts on both, but could never get a straight answer. Is and EGT gauage really preferrable for mixture tuning in an computerized, injected car? Or is the O2 sensor all you really need to do the trick?
rjones is offline   Reply With Quote
Old 10-18-2000, 02:58 PM   #2
adam99rs
Member#: 20
Post
Best combo IMHO (assuming stand alone ecu, not the stock one with piggybacks) is to go with a good EGT guage, and something to moniter O2 voltage (i forget what the DSM guys use...I hav one on my GVR4, but the name escapes me.....SteveS has it in his Turbo RS....).
For using the stock ecu, again, a good EGT guage (HKS, GReddy, APex'I, Omori), and an Apex SAFC is a good choice.
I hav sued mahy different A/F guages (Cyberdyne, Field, etc.), and while they technically work, they are only as accurate as the amount of LED bars they have 9whoich is not many). The more bars they have, the more accurtae they are. The looks of these A/F guages is also questionable (really up to the individual though). But, I guess the same can be said for the SAFc...i have it, and never leave it in the "up" position wher I can read it...I hate how it looks (though it is functional)
adam99rs is offline   Reply With Quote
Old 10-18-2000, 11:26 PM   #3
Impy
Member#: 489
Post
Ok so how do we tune with the EGT?? do we just look for the lowest readings we can get??
Impy is offline   Reply With Quote
Old 10-19-2000, 12:03 AM   #4
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
You need both to do it correctly. If I *had* to pick one, I think I would take EGT.
Sean
Sean McElderry is offline   Reply With Quote
Old 10-19-2000, 12:06 AM   #5
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Post
Agreed.
Chuck is offline   Reply With Quote
Old 10-19-2000, 09:37 AM   #6
adam99rs
Member#: 20
Post
Ahhh...that's the art of tuning! do a search, as EGT's of most, if not all us turbo guys have been discussed before. i did what SteveS did, and tuned on accordance with the DSM crowd.....I was obviously never let down.
Old 10-19-2000, 11:20 AM   #7
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Post
Is an EGT gauge necessary for a N/A car?
I fugure if you go turbo then it is very important but let say you just wanna put some nice gauges in a N/A car.
I know oil temp or oil pressure and water temp would be good, but is EGT necessary?
WRC 555 is offline   Reply With Quote
Old 10-19-2000, 01:18 PM   #8
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Yeah, I have noticed that... I coasted down a hill in 5th for quite a while & the EGT gauge went all the way down to its lowest reading (600). My question is how come the exhaust still makes so much noise if the motor's not combusting?
RidinLow is offline   Reply With Quote
Old 10-19-2000, 02:20 PM   #9
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
I'm using the Jumptronix A/F gauge by Alex Anastousia (I know I butchered his last name!). The great thing about this gauge is that is gives the exact voltage reading from the oxygen sensor; it doesn't use LEDs. There's a huge difference between 0.82V and 0.88V, IMO.
I've finally gotten around to installing a great EGT setup. I'm using the Autometer Phantom series EGT gauge. BUT I'm using a fast-reacting type-K thermocouple probe from Westach (which is really markets to the aviation market). This combination reacts VERY quickly, which is something I really had a problem with using the VDO setup. I can literally watch the EGT's change as I modify throttle position, etc. Pretty cool.
Anyhow, as Adam already stated, go read up around DSM.org for information about acceptable EGT and A/F readings. If your car is tuned to a reasonable state, you should see EGT's at say around 1550F when romping on the car. Personally I've tried to keep mine to 1500F, which is probably keeping me from eeking out that last piece of performance, but it makes me feel safer.
SteveS is offline   Reply With Quote
Old 10-19-2000, 09:04 PM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I have the autometer phantom EGT gauge and don't know about the type of thermocouple, but it too is very fast reacting.
I am thinking about adding a second thermocouple in another location, with a switch to go between the two. What is the BEST location for the thermocouple to see these 1,400 - 1,550 EGT's that you mention?
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 10-19-2000, 09:10 PM   #11
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Larry,
On the header as close to one of the exhaust ports as possible.
SteveS,
Where do you get these thermocouples? Will they work with my Autometer ProComp Ultralite EGT gauge (no gauge sender unit, just hooks directly to the thermocouple)? The problem I'm having in tuning is that it takes a few seconds to hit a peak temp.
[This message has been edited by RidinLow (edited October 19, 2000).]
Old 10-20-2000, 12:32 AM   #12
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Post
You can determine how rich or lean you are running based on the temp of the exhaust gasses. It has been said that the RS is very comfortable at 1400 degrees under load. This is the temp you want to shoot for. Making adjustments to your fuel ratio will be seen in the EGT's. Try it out, it's kinda fun. Rich=cool, lean=hot. You don't want to lean out too much because extreme heat and aluminum heads don't mix. And you don't want to run too rich because you'll kill your cat and you may just blow up your engine over a period of time like I did. Oops. Anywho... this gauge has become invaluable in tuning.
It's cool to see how your engine turns into an air pump while engine braking... no combustion, just cool air flowing thru your engine.
Gauges: Air/fuel vs. EGT? subrandon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 04-18-2005 08:32 AM
A/F Gauge vs. EGT Gauge Neejay Newbies & FAQs 4 10-21-2003 07:51 PM
AFR vs EGT nativo Normally Aspirated with bolt-on Forced Induction Powertrain 5 12-29-2002 01:16 PM
Pyrometer VS EGT gauge, whats the difference? DDMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-05-2002 03:45 PM
air/fuel gauge vs. EGT gauge kaidoy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-02-2001 10:00 PM
