Old 06-24-2004, 09:38 PM   #1
serious
Member#: 22879
Default Wire ? on wrx swap to legacy- rear defogger
Hi all, i'm wondering if i need to connect this wire in my system: It's the wrx ecu A3 connector that goes to the rear defogger/intagrated module?
My legacy doesn't have this connection at the ecu. I'm not using the intagrated module from the wrx harness, so i don't think it needs to be there.
Anyone know for sure?
Brent
serious is offline   Reply With Quote
Old 06-24-2004, 09:45 PM   #2
AKGC8
Member#: 1305
2000 Impreza
I didn't have it hooked up in my 1994 L, no problems.
AKGC8 is offline   Reply With Quote
Old 06-24-2004, 10:18 PM   #3
serious
Member#: 22879
So with your 94 did you have a 02 wrx swap in it or did you just not have the wire/switch hooked up?
If you did have a wrx swap in it, then did the rear defogger system work without this wire connected?
Thanks
B
Old 06-25-2004, 12:06 AM   #4
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
just trace where the wire is further up in the legacy harness and splice the wire into it. It will be worth it if you decide to ecutek the car later on.
Z
Zephyr is offline   Reply With Quote
Old 06-25-2004, 12:29 AM   #5
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
thats the thing, i ran into this as well. I found no wire labeled "rear defrogger" on the RS harness.
ImprezaRSfan! is offline   Reply With Quote
Old 06-25-2004, 01:02 AM   #6
AKGC8
Member#: 1305
2000 Impreza
Yes, 02 WRX swap.
I checked into the diagrams to refresh my memory. Yea, there is no ECU wire to the defogger system on either the 1994 or 1999 L's I've worked with.
My current car, 1999 L with 02 WRX swap does not have it connected to anything. I've got no CEL's and I've got an accessport so ecutek or any other reflashes won't be a problem.
Old 06-25-2004, 01:28 AM   #7
serious
Member#: 22879
Cool, i didn't think it would be a problem. Now if i can just get everything together and working.
What about the speedometer circut? Mine has only 2 wires; a black and white twisted together and also don't go to the ecu. I'm going to install the wrx speed sender unit as the old legacy one doesn't connect to the 5mt/6mt output on the transmission sender unit.
Anyone have this problem too?
B
I need solid info on WRX/STi-> Legacy GT seat swap Donzo Interior & Exterior Modification 24 10-03-2013 11:41 AM
WRX engine to Legacy wiring harness- install ready! serious Legacy Specific Parts 10 04-09-2008 04:19 PM
Another wiring ? on sti swap to legacy harness serious Subaru Conversions 2 06-30-2004 02:53 PM
V8 twin scroll ?'s on swap to legacy serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-31-2003 03:20 PM
Blitz DC Dual TT-Which wire on E-Brake to splice into on WRX? WR_eXe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-26-2001 03:29 PM
