Old 06-24-2004, 11:12 PM   #1
GraimeG
Member#: 64865
1993 Impreza L AWD
Default 1993 subaru Impreza...make fast???
I have a 1993 Subaru Impreza Hatchback. How can I make this thing faster?? (Short of a complete engine swap) Being whooped by stock civics is driving me crazy. I need more power, for not so much money. Any IdeaS?
GraimeG is offline   Reply With Quote
Old 06-25-2004, 12:17 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Gut, Gut and Gut. The cheapest solution but not the prettiest. Remove all the seats, interior carpet, radio, so on and so forth. I lost over 200 lbs. Then remove air conditioner and powersteering, and add a $60 ebay underdrive lightweight crank pulley. Pull the rear washer container. Take a plasma torch and remove exess metal in doors and rear lid. Attack the dash and remove all that you can.
Now you will be considerably faster than you were. How much is another question. When you have another $600 add nitrous.
Thats my plan and I am sticking too it.
Old 06-25-2004, 12:35 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Default Re: 1993 subaru Impreza...make fast???
Turbo kit then. Thats about it. Otherwise, dont expect much HP from anything.
Old 06-25-2004, 03:53 PM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Not many N/A mods out there.
A '93 L will never be a drag car, try to do some effective handling mods, and enjoy your car for what it is.
jamesfacts is offline   Reply With Quote
Old 06-25-2004, 11:14 PM   #5
Scott F. Williams
Member#: 13930
1999 Impreza 2.5RS
Silverthorn Metallic
Impreza GC8 FS: turbo system... one of these days...
I've got a WRX-derived turbo system that's a bolt-in for your car. It was built and plucked from a 1.8l engine in a basemodel car. The kit contains the turbo, intercooler, tapped oil pan, FMU, uppipe, downpipe (no crossmember swap required), and a few other bits n' pieces. I was going to drop it into my '99 RS, but the turbo's really too small to be efficient on the big 2.5l.
Anybody interested? I'd probably take $700 for it all.
Scott F. Williams is offline   Reply With Quote
Old 06-26-2004, 12:11 AM   #6
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
200lbs? Nice! Have you gotten some 1/4 mile times or better yet trap speeds of before and after poundage removal? I know this is more than just straight line performance since weight removal helps out in all aspects of performance. I'm just curious as to how it helped you in your application besides guestimating so many lbs will gain so much in the 1/4. Any testing?
Kevin Thomas is offline   Reply With Quote
Old 06-26-2004, 02:42 AM   #7
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
they say every -100lbs is - 0.1 in he qm.
RS_to_WRX_swap is offline   Reply With Quote
Old 06-26-2004, 06:03 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Which means with 200lbs of weight loss you would go from a ~18.0 1/4 to a 17.8...
Anyho...... Engine swap
Old 06-26-2004, 11:02 AM   #9
GraimeG
Member#: 64865
1993 Impreza L AWD
sooo much money...... Thanks for the advice
Old 06-26-2004, 03:56 PM   #10
Kevin Thomas
Member#: 110
1989 1989 XT6
That's why I wanted some actual info. 100lbs out of a 4000lb car won't yield the same affects as 100lbs out of a 2000lb car. Aack! No matter!
Old 06-26-2004, 05:37 PM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Not really. Price out what a full exhaust plus some other mods like maybe an intake, pulleys, etc would cost brand new.
Then look and see how much EJ25's are going for on the private sale forum. (hint: Under a grand)
Old 06-30-2004, 10:54 PM   #12
JDM_Scobaru
Member#: 57809
or you could just do......A JDM EJ20-G swap like my friend Dan
JDM_Scobaru is offline   Reply With Quote
Old 07-01-2004, 01:56 PM   #13
stickfiguredanny
Member#: 60408
1995 Impreza L
SeaFoam green i think
id suggest doing supension mods first
struts and spring
better sway bars
stickfiguredanny is offline   Reply With Quote
WTT: 1993 Subaru Impreza L GC8 4dr for PRE-96 Impreza Wagon 5sd. sqc151 Tri-State Area Private Classifieds 7 02-03-2008 09:50 AM
1993 Subaru Impreza Won't Start! animestore Service & Maintenance 2 09-15-2004 09:54 AM
?? on retrofitting A/C system on 1993 Subaru Impreza ndkingwv Service & Maintenance 1 05-30-2004 10:33 PM
F.S in IL 1993 Subaru Impreza L RallyKid Private 'For Sale' Classifieds 6 04-04-2004 10:38 PM
F.S 1993 Subaru Impreza L RallyKid Mid West Subaru Owners Club Forum -- MWSOC 4 03-25-2004 11:34 PM
