Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 06-25-2004, 12:00 AM   #1
SupraTT&WRX
Member#: 12452
02 WRX
SRP
Default 245/40/17's in the rear. 225/45/17 in the front
How would this effect handeling. There is only a .1" differance in rolling height? Will it hurt anything?
SupraTT&WRX is offline   Reply With Quote
Old 06-25-2004, 12:34 AM   #2
abaxter34
Member#: 34723
fwd FTL!
understeer gallor. if you really have your heart set on staggered tires id put the fat ones up front. even though its only .1" difference, i think your diffs might not like it in the long run.
abaxter34 is offline   Reply With Quote
Old 06-25-2004, 09:45 AM   #3
Nick M
Member#: 41247
switch it around, bigger in the front, wrx's arent rwd
Nick M is offline   Reply With Quote
Old 06-25-2004, 02:07 PM   #4
subieworx
Member#: 47769
You have your cars confused. Besides there is more fender clearance up front for the larger tires, plus handling will be better. The diffs would not be happy though. All tires are supposed to be the exact same rolling diamter. Subaru even goes as far to say that all tires should be replaced at the same time, for example if you have a blow out replace all four not just he one as it could cause problems.
subieworx is offline   Reply With Quote
Old 06-25-2004, 06:33 PM   #5
Rally1
Member#: 20633
It's not the absolute ride height that's the issue, its the (resulting) rolling circumference you have to worry about, can't be more than 1/4" different.
So as a guess 17" wheels and tires might have a diameter of say 22" vs 22.1"
c= 3.14 * 22
69.08 vs 69.394
so it would cause issues with those numbers, you need to get the ACTUAL numbers to be sure, or better yet measure the actual circumference with a soft tape.
Rally1 is offline   Reply With Quote
Old 06-25-2004, 06:39 PM   #6
Rally1
Member#: 20633
To followup, i'll use real numbers from a set of specs on the Falken ST-115's
3.14159265358979323846
245 40 17 = 24.7"
225 45 17 = 25"
77.597" vs 78.540" almost an 1" !
Not good for the diff.
Old 06-26-2004, 09:17 AM   #7
subieworx
Member#: 47769
Uummmm...pi.
Old 06-26-2004, 12:24 PM   #8
Chuck H
Member#: 20442
245 40 17 = 24.7"
225 45 17 = 25"
Take that analysis one step further:
245/40-17 = 77.60" circumference = 816.5 revs/mile
225/45-18 = 78.54" circumference = 806.7 revs/mile.
Assuming you're travelling at 60 mph on the highway, the plates in your center differential have a 10 RPM difference in speed. I know that Subaru has that 1/4" overall circumference spec on tire size difference, but that one has always seemed to me to just be a legal trick to always give them an excuse to never replace a diff under warranty. Because if that spec is true, it means that the diff can't tolerate more than a 2.5 RPM rotational difference without being damaged, and in that case, they have no business selling it. If you believe their specs, then an 80 thousandths of an inch difference in tread depth due to uneven tire wear is enough to throw you out of spec and void the warranty on your differential.
I'm not saying that running different sized tires is a good idea, but I don't think it's really as destructive as they'd like you to believe as long as the tires are close.
Chuck H is offline   Reply With Quote
Old 06-27-2004, 01:16 AM   #9
Rally1
Member#: 20633
Thumbs up
225/40/18 Kumo MX's(90%) and 225/45/17 Nokian WR's(80%) Swine Private 'For Sale' Classifieds 40 07-02-2006 12:43 AM
Wanted used 225 45 17 in ny subalou1 Private 'Wanted' Classifieds 2 05-17-2005 06:24 PM
Madison / Baraboo area installs in April & 225/45-17 S03's used! GLwagon Mid West Subaru Owners Club Forum -- MWSOC 26 04-25-2005 01:54 AM
FS: Potenza RE070 Tires 225/45/17 in CT B18flip Private 'For Sale' Classifieds 4 03-07-2005 09:17 AM
