Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-25-2004, 01:27 AM   #1
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
Default Ludespeed Kit going in...
I just picked up a new Stage3 kit from goatspot and am installing this weekend. Any pointers? Going in a 99 EJ22. Wish me luck!! I will tell you how it goes on the other side.
Brandon
blaznc is offline   Reply With Quote
Old 06-25-2004, 02:46 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Hardest part is the oil pan. Loosen the motor mounts and jack the engine up a bit to gain some clearance to get to the rear bolts on the oil pan. Other than that it's really not hard. Just take your time and be careful. Doublecheck that everything is tight.
Drac9 is offline   Reply With Quote
Old 06-25-2004, 03:56 AM   #3
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
be extra careful with the screw on the stock fuel pressure regulator it strips easily. and start everything off loose because you might have to do some negociating to get it to fit right.
Derk1127 is offline   Reply With Quote
Old 06-25-2004, 04:03 AM   #4
Kotir
Member#: 17300
1993 Widebody Wagon
625whp e85
Yeah the screws on the stock FPR suck... I replaced mine with bolts instead of easy to strip screws...
Kotir is offline   Reply With Quote
Old 06-25-2004, 10:43 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
If you can't get the screws loose on the FPR, just use a vice grip and it'll come loose. They're loctited in, so you have to break that seal.
When doing the piping install, tighten from the head back. Get everything in place and the bolts in/near snugged, then tighten the headers, uppipe, turbo, then downpipe and wastegate. You can also adjust where everything is sitting during this, which is a good thing if you find clearance issues.
Turbo Kit Owners, READ. Especially Ludespeed kit owners. ImprezaRSX Normally Aspirated with bolt-on Forced Induction Powertrain 20 02-05-2004 03:45 PM
Any Interest in a ludespeed kit? Midwayman Mid West Subaru Owners Club Forum -- MWSOC 9 08-16-2003 04:29 PM
ludespeed kit in Legacy?? etam Legacy Forum 8 04-02-2002 09:30 PM
Has anyone installed a Ludespeed kit yet? IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 05-19-2001 12:09 AM
Ludespeed kits shipping Midwayman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-16-2001 09:53 AM
