#1 |
Member#: 64963
i have a 02 wrx 4eat, i want to convert it to a 5mt, can someone tell me how difficult is this? who ever have done it, or knows the procedures and parts involved, can you share info on this, is the center diff and rear diff same for auto and manual? any help is appreciated
#2 |
Member#: 21641
International
Vehicle:4EAT 12.185@110.34 Now a 6MT! beyatch! |
why would you do that? at least convert it to a 6spd. it's near pointless to switch to a 5mt, unless is was a rebuilt 5mt.
#3 |
Member#: 58325
Vehicle:1995 Legacy LS Dark Green |
i'm getting ready to do this to a 95 legacy...with a 5 speed out of an impreza (not sure of the year though)...except i'm not sure if the front and rear gearing will match up.
#4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
The center diff is part of the trans and they are different, the auto has an electronically variable front-rear split while the manual is mechanical and fixed at 50-50.
You would need to change a lot of parts in the drivetrain, also the flywheel and the ECU. This is not a cost-effective conversion. If you want an MT car you would be far better off selling your auto and buying one. |
#5 | |
Member#: 64963
#6 |
Member#: 64370
NESIC
Vehicle:03 bugeye wrx 07 avalon |
i think that if you want to keep the price within reason your best bet is to go to several junkyards and pray that you find your manual tranny there...and then you might as well take the other parts like the flywheel and ECU too....keep us posted
#7 |
Member#: 58325
well...i found a tranny w/ linkages, pedal set, and needed cables to hook it up for like $300. just need my flywheel and clutch assembly to come in ($50 for the flywheel & $160 for the clutch assy.)
a friend and i will be doing all the work. i talked to the guy at the salvage yard about possibly needing the ecu...he said he'd just swap me for mine. just gotta wait for my parts! that's the hard part for me. being said that the center diff on the manual is a mechanical piece rather than electronic...how possible would it be to get it locked for RWD?? i'd rather do that than risk eating the gears due to the possiblity of the gears for the front axles being different from the ones in the rear end. the tranny is coming out of an impreza...i'm not sure what year (1st gen??) and it's gonna go into a 95 legacy. |
| Thread Tools | |
| Display Modes | |
| Auto to Manual conversion successful! | PaulN | Transmission (AT/MT) & Driveline | 6 | 04-19-2009 12:08 PM |
| Is and Auto to Manual Conversion Possible? | F=ma | Transmission (AT/MT) & Driveline | 11 | 04-25-2002 01:07 AM |
| new engine or atleast auto to manual conversion | funkadellic69 | Normally Aspirated Powertrain | 2 | 02-21-2002 08:20 AM |
| auto to manual conversion with big torque expectations | kaneda3 | Factory 2.0L Turbo Powertrain | 17 | 07-21-2001 01:01 AM |
| auto to manual conversion | kaneda3 | Normally Aspirated Powertrain | 5 | 07-20-2001 01:54 AM |
