Old 10-19-2000, 11:12 AM   #1
DarkLite
Member#: 2005
98 Vw Jetta VR-Sex
Cool White...
Question Which is the Best turbo? HELP!
IHI turbo
T28/T3
T3/Super 60
T3/T4 hybrid
i dont know of ne others also would they compare to ball bearing turbos.....
i mean what would be the best turbo for my auto 2000 RS ..
i want it to spool up as quickly as possible with no lag and start at the lowest RPM range and End the farthest thanx....
please HELP and explain all in Laymans terms thanx....
also price of each...
thanx
-DarkLite
DarkLite is offline   Reply With Quote
Old 10-19-2000, 11:39 AM   #2
legacyGT00
Member#: 2052
Post
If you find something like that, let us all know.
Ball bearing turbos are supposed to be more durable, from what I've read. Search around, I know somebody posted about a company that makes a ball bearing turbo that can work on the RS. Of course, they're way more expensive.
Check out: http://www.vishnuperformance.com/ http://www.carmodifcations.com/
I hear that Car Modifications is working on a new twin turbo set up. I'm going for the TEC-II first (from Vishnu), then a turbo (twin?) later.
I believe that half of Minnam went to Vishnu and the other half went to Car Modifications. Lots of people feel pretty good about the Minnam Stage II.
legacyGT00 is offline   Reply With Quote
Old 10-19-2000, 11:53 AM   #3
Tim Prudence
Member#: 216
Post
If you want the one that spools quickest, then it's the IHI (though there's lots of IHI, I assume you are talking about the one JC sports was offering). However you'll be limited to around 230 HP in stock trim.
Ball bearing sections allow the turbo to spool a bit quicker.
Tim Prudence is offline   Reply With Quote
Which is the best turbo timer? eL_DiAbLoFeR Newbies & FAQs 3 09-07-2008 09:23 PM
So...which is the best turbo kit... adofly Built Motor Discussion 0 12-24-2007 07:14 AM
Which is the Best BOLT ON TURBO?? ac23 Newbies & FAQs 25 06-06-2007 01:52 AM
Experts question which one is the best turbo Roadrunner(NL) Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 06-27-2002 02:22 AM
Which is the Best Turbo Exhaust System for WRX ImprezaSTIVI Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-09-2001 07:51 AM
