Old 10-18-2000, 10:07 PM   #1
elemental
Member#: 2701
'00 obs
Question Fire out the exhaust?
This is not subie related obviously. I just don't really have other sources for questions of mine of which there is no pre-prepared answer since I don't know many if any into the technicals of cars or have the knowhow to answer any kind of tech-related questions... But enough filler... Anyone want to explain why it is that some cars spit flames out the exhaust? I can't seem to reason it out with the little knowledge I've gained by reading some of these forums and other engine related texts... I've seen it in person on the street (Which im not sure is legal) but it had be smiling. Just wanted to know why it happens. Thanks.
elemental is offline   Reply With Quote
Old 10-19-2000, 12:19 AM   #2
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Post
most of the time when a car spit fire mean that the car is running pretty rich at high rpm
when running rich down-shifting might make your exhuast spit some fire.
spitting fire out of your exhuast is not always good. Really depends on your setup and how the car is tuned.
RX-7 tend to do that a lot since its running rich most of the time. just a exhuast and header can make that possible.
one of my friends MR-2 turbo do that when down-shifting at high speed. saw it first hand when i was behind him. looks pretty cool. his set up was a header, exhuast, and change the stock turbo to a bigger one (TD06)
hope this helps
michael
Michael is offline   Reply With Quote
Old 10-19-2000, 09:22 AM   #3
ChaosThom
Member#: 1507
2003 Tiburon
Rally Red
Thumbs up
I have a 1-ton Dodge van with a 360 V-8 sporting a 4-barrel carb. Coming off the throttle quickly after hard acceleration will always cause a backfire in the exhaust. I've been told that flames have shot out as much as 2 feet.
The problem is fuel that is not burned in the engine under the condition I described. Bottom line - it's running too rich under hard acceleration.
ChaosThom is offline   Reply With Quote
Old 10-19-2000, 09:35 AM   #4
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Post
hey what's up mike! stop by mah 7-11 again
chrisC
silverSurfer is offline   Reply With Quote
Old 10-19-2000, 09:38 AM   #5
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Post
sup chris
i stop by that 7-11 once a while
most of the time its mon and wed after i play some bball.
well let me know when you are going to be there or we can try to have a mini meet in flushing or something
laters
michael
Old 10-19-2000, 10:05 AM   #6
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
I in no way recommend doing this but. When I was in High School way back when. To scare the poop out of someone next to you (and mostly destroy the exhaust); while driving down the road you could turn off the key for a few seconds and kill the ignition (no steering lock at that time to worry about) let the whole exhaust fill with unbrunt fuel then turn on the key. Kaboom, w/ flames out the back. This usually made an oval muffler round too.
Peaty is offline   Reply With Quote
Old 10-19-2000, 10:45 AM   #7
wistful
Member#: 745
2004 STi
Java Black Pearl
Post
formen.ign.com had an article abuot this a while ago. It went from home-rigged to professional systems. I think the most basic was hooking a spark plug into somewhere near the end of the exhaust tip. This would ignite whatever didn't ignite or extra fuel or whatever. Professional were napalm-based flame throwers.
Don
wistful is offline   Reply With Quote
Old 10-19-2000, 10:45 AM   #8
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Wink
To add to what was already said, when the exhaust valve opens, the unburnt air/fuel mixture gets sucked thru the exhaust valve and is ignited further down the exhaust pipe.
Zee
Sunrise City Rider is offline   Reply With Quote
Old 10-19-2000, 10:51 AM   #9
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Brings new meaning to "smoking the competition," eh?
RidinLow is offline   Reply With Quote
For those who get occasional smoke off the turbo or out the exhaust... ToddStratton Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-03-2003 10:35 PM
flames out the exhaust? jasona Normally Aspirated Powertrain 19 02-17-2003 04:18 PM
Flames out the exhaust Phatshiet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-20-2002 02:26 AM
Kit installed. Now there's blue smoke out the exhaust Drac9 Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-03-2002 03:01 AM
How bad is it to leave out the exhaust manifold heat shields? Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-10-2002 11:30 PM
