Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-15-2000, 05:24 PM   #1
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Question clutch bleed procedure
Can someone post the correct clutch bleeding procedure?
Vacuum? (tried that and got a lot of bubbles, I think my kit is tool old).
Pressure?
ANZAC_1915 is offline   Reply With Quote
Old 10-15-2000, 05:33 PM   #2
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Post
ahhhhhhhhhhhhhhhhhhhhk..
Email either ARG or Imprezer.
Me and Imprezer did this on my car and it was a b()Tch!!!!!!! So was the brakes..
Only because we didn't know how to do the clutch
STi Sev is offline   Reply With Quote
Old 10-15-2000, 08:53 PM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Lightbulb
We made our own pressure bleeder by drilling a hole in the cap and using an electric tire inflator.
It at least got it to the stage where it is drivable.
We got nowhere using vacuum bleeding.
Glenn
Old 10-15-2000, 09:06 PM   #4
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
Hey Glenn,
It's nice to see you here, finally.
Anyways, bleeding the clutch is no different from bleeding the brakes. The only difference is, you need to push and pull the clutch pedal with your hand. Do it slowly. Don't let the spring pull or push the pedal for you. I repeat, so it VERY SLOWLY. Push and pull the pedal VERY SLOWLY 3 times, hold the pedal to the floor and have you buddy open the valve for a sec. Keep doing it until the pedal gets firmer and firmer.
The trick is to pump the pedal slowly. Did I say slowly? Yes, do it very slowly, hehe.
Let me know if it works for you.
Imprezer is offline   Reply With Quote
Old 10-15-2000, 11:30 PM   #5
ARG
Member#: 386
1999 Impreza RS-S
Rally Blue & Supercharged
Have a Nice Day?
You drilled a hole in the cap and forced air into it? Sure, that will work, but now you need a new cap!!
ARG
ARG is offline   Reply With Quote
Old 10-16-2000, 07:31 AM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Bah... whip out the JB Weld.
ColinL is offline   Reply With Quote
Old 10-16-2000, 08:08 AM   #7
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
The bleed valve for the clutch is located under the plenum/large airbox. You will need to remove it to get to the valve.
You will need a 10mm (or was it 12mm) wrench to open and close the valve. You will also need some aquarium tubing (6-8 inches of standard 1/4 inch variety), a small bottle, and a second person to actuate the clutch, and don't forget the brake fluid.
Take the bleed valve cap off the nipple and wipe off any accumulated dirt around the valve. Fit the tubing to the nipple and stick the other end of the tubing into the bottle. The bottle end of the tubing should fit all the way to the bottom (use tape to hold it in place if neccessary). Find a convient place in the engine bay to secure the bottle. Have your friend pump the clutch pedal. You will notice the slave cylinder pushing on the clutch fork. This is what will do all the work of pushing the clutch fluid. Have said friend hold down the clutch pedal and open the bleed valve (counterclockwise). Watch the clutch fork as it drops. When it has almost finished moving, close the bleed valve. Have friend reach down and pull clutch back up by force then have friend pump on clutch.
Repeat until clutch resourvoir is almost empty.
If this is your first clutch bleed you will notice dirt at the bottom of the resouvoir. Some people have wiped the dirt away with LINT FREE shop towels, others have left the dirt alone, others still have flushed the dirt out with lots and lots of brake fluid.
Add clean brake fluid to resourvoir and Repeat until the fluid in the tubing is clear and golden.
Revision is offline   Reply With Quote
Old 10-16-2000, 09:15 AM   #8
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
Question
So the one man vacuum bleeder tool doesn't work on the clutch? I just bought one. I guess the issue is whether the hand pump can pull fluid from the reservoir past the seals in the master cylinder or not. Or am I thinking about this wrong?
Travis R is offline   Reply With Quote
Old 10-16-2000, 09:48 AM   #9
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post
You know, the Joel Gat Special '99 tranny with cable clutch isn't looking so bad right now....
Necromancer is offline   Reply With Quote
Old 10-16-2000, 10:36 AM   #10
Joel Gat, 1.8L
Member#: 32
Post
Hello,
I was just going to say, Joe, that I bleed my clutch by turning the barrel adjuster. Takes me about 30 seconds to adjust the clutch and no dirt
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Old 10-16-2000, 10:40 AM   #11
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Wait until you have an aftermarket clutch with lots of clamping force and you're snapping clutch cables left and right. Then you'll be at the junkyard scavenging another slave cylinder...
Old 10-16-2000, 11:51 AM   #12
Joel Gat, 1.8L
Member#: 32
Post
Hello,
The ACT pressure plate gives me no problems Of course, you have to realize that the cable clutch setup moves the pivot point closer to the throwout bearing AND is longer passed the pivot point, so I'd roughly guess that the cable setup gives you about twice the lever arm that the hydraulic system has to work with, maybe more. So I have mechanical advantage on my side
Joel, with a clutch pedal that's easy as pie to push in...
Old 10-19-2000, 10:25 AM   #13
Travis R
Member#: 153
'07 Mazda CX-7, '91
Exclamation
So getting back to the hydraulic clutch issue....
Revision, is your info from the shop manual, or from personal experience? I tried bleeding it last night and I think I only made it worse. When I "Have friend reach down and pull clutch back up by force then have friend pump on clutch." is the bleed valve open or closed? Should I pull the clutch lever away from the slave cylinder while he is pumping? What am I trying to accomplish by pumping the pedal? Get more fluid into the system?
Right now the clutch pedal is about 2 inches from my floor board, and barely disengages the clutch. It would seem to me that there is either a crap-load or air in the system or not enough fluid.
Any help appreciated.
[This message has been edited by Travis R (edited October 19, 2000).]
STi brake bleeding procedure? ChrisF Brakes, Steering & Suspension 19 04-14-2015 09:44 PM
Clutch Bleeding Procedure on 02 WRX DreWRX Transmission (AT/MT) & Driveline 10 04-20-2010 01:13 PM
ABS Bleed Procedure? mikesoob7 Brakes, Steering & Suspension 11 04-06-2005 03:47 PM
Sti brembo brake bleeding procedure? serious Brakes, Steering & Suspension 2 05-30-2004 11:43 PM
wrx clutch bleed procedures JSBOOST Transmission (AT/MT) & Driveline 3 04-08-2004 10:47 AM
