Old 01-04-2001, 11:29 AM   #1
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post Replacing stock cats with hi-flow cats
Emissions laws aside...the only problem would be with the O2 sensors correct? I'd throw a check engine light right? So if I have TWO hi-flow cats then I can plug in both O2 sensors and that would solve the check engine light being tripped...or does it not work that way?
Keiho is offline   Reply With Quote
Old 01-04-2001, 03:32 PM   #2
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
You'd be better off putting a voltmeter on the two O2 sensors. Record the differences. Then install a high flow cat...or no cat. Then install a resistor in the rear O2 sensor to make it send stock-like voltages to the ECU.
In fact, someone on this board has done this. Try a search. Good luck!
Sean
Sean McElderry is offline   Reply With Quote
Old 01-04-2001, 05:02 PM   #3
Tim Prudence
Member#: 216
Post
I replaced both my cats with a single high flow cat (and a turbo), and I have no check engine light. This is on a MY99.
Tim Prudence is offline   Reply With Quote
Stock cat vs Hi-flow cat whittleman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-19-2004 12:45 PM
MI: TXS stealth turbo back with hi-flow cat for sale cherrywrx Private 'For Sale' Classifieds 13 11-12-2003 01:52 PM
xcceleration turbo back system with hi flow cats showcasewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 63 10-30-2003 01:14 AM
REplacing both cats with high flow cats? DarkLite Normally Aspirated Powertrain 8 10-18-2000 07:15 PM
