#1 |
Member#: 1955
I have heard that the 2000 2.5rs has a limited slip. If this is true and anyone knows where to get one please let me know.
Thanks, rangere7
#2 |
Sea to Sky - OWNED
Moderator Member#: 610
VIC
Vehicle:2003 Lexus IS300 Graphite Gray Pearl |
Yes, the MY00 has a rear lsd.
You can try looking in junkyards for a wrecked MY00, or pick one up from a dealer. I think you'll need the associated "rods" (sorry forget what it's called) that stick out of it as the MY98/99 ones don't fit. Am I correct here guys? |
#3 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2006 B9 Tribeca LTD 2005 Impreza 2.5 RS |
Those would be called axles
#4 |
Member#: 1888
South East
#5 |
Sea to Sky - OWNED
VIC
Ahahahaha...yea....axles...that's what they're called
#6 |
Member#: 329
Vehicle:1995 325i Arctic Gray |
Yeah, but he swapped in a Cusco clutch-pack diff... not so good if you ever do anything else except slide around on dirt!
#7 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
Nah, a clutch limited slip is fine. You can't shim them too aggressively or you can't turn on tarmac, unless you have the power to break loose the back tires and slide the rear end around.
But if you shim them for a more conservative lockup-- like 25% or so-- they work great. Torsen is better though, that's what I'd buy. I'm a tarmac-loving looser though. ![]() |
#8 |
Member#: 251
Vehicle:1998 Impreza 2.5 RS Black |
ColinL-
What do you mean by "shim" the LSD? Thanks, -Chris |
#9 |
Member#: 114
The clutches are held together by spring tension. If you add shims, the tension becomes higher and decreases the speed difference allowed between the axles.
#10 |
Member#: 1135
BAIC
Vehicle:2005 WRX WAGON Silver |
Go look at the issue of SCC from a few months back. I believe Shiv has swapped it into his '99 RS since the '99 didn't have it. It's all explained in that months issue.
| Thread Tools | |
| Display Modes | |
| White rear wing spoiler for 2000 2.5rs /lowering springs | masters324 | SCIC Private Classifieds | 5 | 06-01-2010 08:26 PM |
| 2000 2.5rs and 2000 LGT same struts? | damonmlime | Brakes, Steering & Suspension | 3 | 04-06-2006 10:10 PM |
| I'm thinking about trading in my 2000 2.5RS Impreza for the Outback limited sedan | Piecode314 | New England Impreza Club Forum -- NESIC | 10 | 05-04-2004 07:59 PM |
| 02 2.5RS seats in 2000 2.5RS (GDB in GC8)? | ERaab212 | Interior & Exterior Modification | 5 | 06-04-2003 05:52 AM |
| 2000 2.5RS vs. 2002 2.5RS Differ? | Lightning Jack | Newbies & FAQs | 0 | 04-13-2003 11:14 PM |
