Old 06-25-2004, 09:32 PM   #1
Subvert
Member#: 64468
Default Disabling day-time running lights?
I've seen other WRXs on the road with them off.
Subvert is offline   Reply With Quote
Old 06-25-2004, 09:36 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Unplug the relay plug behind the glove box...
See: http://www.subaruparts.com/diag/?mod...category=836-1
Old 06-25-2004, 10:34 PM   #3
spongejosh
Member#: 62783
Midnight Black Pearl
spongejosh is offline   Reply With Quote
Old 06-26-2004, 09:52 AM   #4
doobie
Member#: 6570
04 WRXSW
9.3 TRB0 CNV
It is quite simple in theory the hard part is getting your hand in there. It was a white plug on my ride behind the glove to the right. Good luck and dont get your hand stuck.
doobie is offline   Reply With Quote
Old 06-26-2004, 09:56 AM   #5
Davenow
Member#: 23676
You dont have to unplug the PITA thing behind the glove box. Just unplug and remove the DRL module in the engine compartment I forget where it is (its EASY to get to) as its been since the car was 3 hours old that it has been gone from mine. But its like 1 10mm bolt and unplug and its out.
Old 06-26-2004, 10:26 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Underhood unit = dropping resistor. Not the main control unit, will disable the DRLs on stock lights but NOT for HIDs or some other aftermarket lights (depending on how they are wired). The main control unit will still apply power to the headlight circuit so if an alternate ground path is present the low beams will still come on.
In-car unit by glovebox = main DRL control module. Will disable all DRL functionality for good, regardless of what lights you install.
Old 06-26-2004, 10:56 AM   #7
SIMPFLY
Member#: 54794
Jan 2004 wrx @ 5 mi
Apr 2016 @ 234,567 mi.
check out the eighth pic in the thread below......black connector behind the glove box.
http://forums.nasioc.com/forums/show...&highlight=drl
SIMPFLY is offline   Reply With Quote
Old 06-26-2004, 04:02 PM   #8
BeeGee
Member#: 27724
1970 F100
Black/White
Agree with Mulder. However, if you just want to disable DRL's on the stock lights just unplug the connector from the silver giant tic-tac looking thing under the solenoid cover all the way against the passenger side of the engine bay.
BeeGee is offline   Reply With Quote
Old 06-27-2004, 12:12 AM   #9
0260B4U
Member#: 33249
2003 WRX
white
Just make sure you wrap it with a good deal od tape and get it out the way or it may drop near the turbo and melt like mine did
0260B4U is offline   Reply With Quote
disable day time running lights? sUpRSikwRx Electrical & Lighting 7 12-08-2008 11:43 AM
How 2: Disable Day time running lams in 07 WRX?? SLCDUB Electrical & Lighting 2 05-31-2007 02:57 PM
How to Disable or Turn off the Day time Running light mop Electrical & Lighting 1 06-23-2006 06:16 PM
Disabling Day Time Running Light? White4drWRX Interior & Exterior Modification 6 09-28-2001 03:42 PM
Disabling Day-time Running lights mcv9802 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-17-2001 03:55 PM
