Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 10-18-2000, 08:59 AM   #1
Member#: 922
16 WRX (white)
04 FXT (red)
Post Wide-band A/F Guages?
I called Autometer and they don't make anything. From my understanding the wide-band O2 sensor operates in the 0-5V range versus the normal O2 sensor range of 0-1V.
Now theoretically you could make something to cut the voltage in 1/5th going into a guage and this should result in the same reading as a normal O2 sensor, right?
The only problem this may cause is less voltage being read by the ECU, but I'm not positive on that one since I don't know electronics too well.
Also for those of you interested, I found <a href="http://www.students.tut.fi/~eppu/dev/EGO-bar.html" target="_blank">this link</a> in an old thread explaining how to make your own A/F ratio meter with simple electronics. Makes me wonder if there isn't a chip out there to do the same from 0-5V as that one does to 0-1V.
BTW, my point behind this thread is wondering if there are pre-made guages for us wide-band O2 people that don't cost an arm and a leg.
[This message has been edited by 8Complex (edited October 18, 2000).]
Old 10-18-2000, 09:25 AM   #2
Member#: 188
2004 Forester XT
24k gold on white
So in theory, if I connect a resistor that decreases the voltage by 80% inline to the A/F meter, my meter should work. Correct me if I am smoking crack again.
nizz is offline   Reply With Quote
Old 10-18-2000, 09:44 AM   #3
Homicidal Maniac
Member#: 1612
2008 STI
Since this issue is coming up again, let me repost this thread: http://www.i-club.com/ubb-files/Foru...ML/003366.html
If you guys have any ideas on the results, please let me know.
Old 10-18-2000, 10:51 AM   #4
Member#: 1919
1994 Legacy Turbo
I posted that link to http://www.students.tut.fi/~eppu/dev/EGO-bar.html a couple of days ago. You can use the same National Semiconductor LM3914 for a 5 volt signal. In fact, the ciruit diagram is given in the LM3914 data sheet (http://www.national.com/ds/LM/LM3914.pdf) on page 2.
Nigel is offline   Reply With Quote
wide band guage question 05blkwrx Electrical & Lighting 0 12-27-2006 06:35 PM
HELP!! Autometer A/F guage not compatible with 2002 WRX wide band O2 sensor?? aznfoos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-09-2004 09:28 PM
Wide band vs narrow band O2 mitch808 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 06-12-2002 04:13 PM
('93-'01) Wide band O2 sensor voltage range jeffg Impreza Forum 5 06-05-2001 02:26 PM
New Info about my00 wide band o2 sensor??? skidplatez Normally Aspirated Powertrain 3 11-03-2000 11:08 PM
