Old 10-16-2000, 01:05 PM   #1
FargoRS
Member#: 419
Cool Anyone try an Air/Fuel meter
I have seen some cheap air/fuel meters for about $130 for sale at some of the Impreza tuner sites. Has anyone installed one? If so, are they showing any lean conditions on the 2000/2001 aftermarket air intake setups vs. the stock setup? Also, are they pretty easy to install?
http://www.spomotorsports.com/images/Spo/arm1.jpg
Thanks,
Mike
FargoRS is offline   Reply With Quote
Old 10-16-2000, 01:19 PM   #2
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
You can get the Autometer Phantom series A/F meter for $60.00. It is a good gauge. I've used one for a few months in my RS. Yes, they are extremely easy to install. Just attach power and ground, and then take the signal from your ECU and you're done.
Sean
Sean McElderry is offline   Reply With Quote
Old 10-16-2000, 01:29 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Am I wrong in thinking that the guage is just based off of the voltage coming out of the O2 sensor? I mean, why couldn't someone just make some kind of digital readout of the voltage and use that? Personally I would think it'd be preferred since you could do it in a much smaller space...
Old 10-16-2000, 01:33 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
An air fuel guage is just a voltage meter. The jumptronix (www.jumptronix.com) a/f guage is a perfect example of this. Keep in mind that on MY00+ the front o2 sensor is a broadband o2 sensor which is not compatible with a standard air fuel guage. You would have to either weld in an additional o2 bung for a dedicated o2 sensor or use the rear(after the cat) o2 sensor which is delayed and not as accurate.
Old 10-16-2000, 01:39 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
You know, in theory that front wide-band O2 sensor would be just fine if we knew what was too rich/lean and what was just right, right? All it is is a number, so what if it is different as long as it reads the same...
Old 10-16-2000, 02:13 PM   #6
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Yeah, but the problem is getting a meter that is able to read a 5V signal.
RidinLow is offline   Reply With Quote
Old 10-16-2000, 02:16 PM   #7
Greg Sharpe
Member#: 741
04 EVO SSL
Asphalt Black
Post
I've heard that low impendence voltmeters provide a "short-circuit" for O2 sensors, causing the O2 sensors to become rather inaccurate.
Greg Sharpe is offline   Reply With Quote
Old 10-16-2000, 02:20 PM   #8
tulit
Member#: 338
09 STi
Post
Greg is right.
You need to be very careful with just hooking a voltmeter to the signal line.
The truth is, low internal resistance voltmeters (usually cheap ones) can cause damage to the sensor and the ECU, but effectively giving the signal a path to ground.
tulit is offline   Reply With Quote
Old 10-16-2000, 03:53 PM   #9
Nigel
Member#: 1919
1994 Legacy Turbo
Post
Here you go guys!!! A DIY EGO meter using a National Semiconductor LM3914. Parts shouldn't cost more than $10.
http://www.students.tut.fi/~eppu/dev/EGO-bar.html
I found this courtesy of a guy on www.zcar.com
Nigel
Nigel is offline   Reply With Quote
Old 10-17-2000, 07:38 PM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
Thanks Nigel, I think Mike Jerry's turbo RS has a display similar to that.
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 10-18-2000, 08:10 AM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
I thought about something like that, but after doing some voltage checks on the front o2 sensor on my MY00, I have no idea what the optimal range should be.
[EDIT] heres another one while we are on the subject: http://www.myzero.com/gauges/afgauge.html
[This message has been edited by stimpy (edited October 18, 2000).]
anyone running zeitronix zt-2 air/fuel meter ? dElKwOn General Community 0 11-15-2004 12:21 AM
Selling Apex-i S-AFC, Intake, and Air/Fuel Meter ShawnMitola New England Impreza Club Forum -- NESIC 7 04-24-2001 04:40 AM
Air/fuel Meter were to buy at good price anyone know Jimmy Normally Aspirated Powertrain 5 04-05-2001 11:38 AM
where is the ecu? yes, this is air fuel meter related! Dane Technical Forum Archive 1 05-08-2000 03:42 PM
Air / Fuel meter installation (HELP!) Dane Technical Forum Archive 6 05-07-2000 11:47 AM
