Old 10-15-2000, 06:33 PM   #1
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
Post just long does it take for oil to burn off? sheesh...
ever since the turbo install, and removal, i leaked some oil into the headers, and since the heat shields have some kind of material that absorbed the oil, i wouldn't know how long it'll take to get rid of it. so what do i do now? barbeque? i guess it'll have to do unless anyone else has any suggestions...thanks
-matt
kid22 is offline   Reply With Quote
Old 10-15-2000, 07:11 PM   #2
Avenger
Member#: 1234
Post
Try spraying some brake clean on it. Make sure your header is cold and the engine is not running.. that stuff is alcohol so it could burn.. trust me I saw that stuff burn right across the shop floor when we were heating up some stuff with fire.. looks sweet with the flame sweeping across the floor!
Avenger is offline   Reply With Quote
Old 10-15-2000, 08:44 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
IMO the heat shield don't absorb oil, what they do is trap it. They are like a clamshell that covers 180-270 degrees of the piping, and basically fluid gets in there can't escape unless it boils out.
I got a fair bit of oil and coolant inside mine during my cam install and it took a good 10-15 minutes to burn off. Not one wisp of smoke since either.
ColinL is offline   Reply With Quote
Old 10-16-2000, 09:05 AM   #4
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
Post
yeh i figured, the headrs aren't burning oil anymore from from the cat to the resonator there is another heat shield with a cotton type of cloth in between...ah hah, found, simple green should do the trick i hope, thanks guys
-matt
Old 10-17-2000, 11:35 AM   #5
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
Post
well, i pressure washed the ride, and the passenger header still has oil in it, sheesh, didn't think there was a pool in there, thanks for all ur help guys.
-matt
how long does it take for springs to settle? prometheum Brakes, Steering & Suspension 3 10-09-2006 07:25 PM
How long does it take for Marijuana to clear you system? outbacksport Off-Topic 35 09-20-2006 10:24 PM
how long does it take for you to change base maps with AP? intence Engine Management & Tuning 7 01-06-2006 07:19 PM
How long does it take for food to turn into poop? Hank3 Off-Topic 23 08-08-2005 12:55 PM
How long does it take for CEL to reset itself poopysnaps Normally Aspirated Powertrain 1 04-26-2003 06:15 PM
