#1 |
Member#: 191
NESIC
Vehicle:2012 J train Brown |
http://forums.nasioc.com/forums/show...hreadid=585393
take a look there, that is my situation. No one is on that forum, so I'm gonna post here hopeing I can get some info. I have about 4 horus until I can get this done, so BREAK Y0 SeLF and GIVE me da inFO! ![]() ehhehe Sorry for the cross post, but info= needed now. wee
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
You can't remove the drum, it has to be there to hold the wheel on.
You could pull it off to see what's going on in there. Is the fluid level in the reservoir going down, and is there any fluid or wetness visible on the backing plate behind the drum? If you heard the noise only when braking it might just be that the shoes are metal-to-metal, but if you hear it all the time it may be that something came apart in there. |
#3 |
Member#: 191
NESIC
thanks for the response...
1. damn. (hopeing I can remove the drum) 2. the fluid level seems ok, and I haven't seen any wetness. I hear the noise all the time. It is louder when i"m at a slow roll, and when I go faster, it just isn't as obtrusive. more of a screeeeeeeeeetch screeeeeeeeeeetch (increase speed) screetch screethc scth sth th th th ![]() get the idea? ![]() Ok, so point number 2 is that I have done disk brakes a few times. I did a search on the brake forum and haven't found any good instructions for removing a drum brake. How hard is it? Keith edit: I know this sounds dumb, but I can just take everything out of the drum brake? whatever I can get out, take out? |
#4 |
Trust no one
The drum should pull off, although they tend to get rusted on sometimes. You can whack it with a rubber mallet (don't use a sledge or it will break the drum), that should loosen it if it's stuck. It also helps to back off the parking brake adjustment to retract the shoes.
Once you get it off any issues with the brakes should be obvious. Given the age of the car maybe one of the springs broke or something like that. You can't take the brake assembly out though, or you will end up with no brakes. |
#5 |
Member#: 191
NESIC
cool deal man, I think I'll give this a try in a few mins
If its one of the springs or something, I'd be really happy![]() If that one brake doesn't work, I could care less....just needs to get down to jersey. I have 3 other brakes that work fine ![]() keith |
#6 |
Member#: 23934
teh keif...in jersey?! break out the beers!
#7 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
rear drum .. is that like das pooper
#8 | |
Member#: 191
NESIC
seems
#9 |
Member#: 23934
where in jersey you going to be? i may not be the most mechanically inclined but always willing to help.
#10 |
Member#: 1711
South East
Vehicle:140 rogue points! 2013 GBS BRZ Limited 6MT |
IIRC you have to take off teh wheel nut to remove the drum - I think thats the way it was in my wagon. After the wheel nut is off and you don't have the parking brake engaged the drum should slide off - if not there are 2 holes in the drum that you thread a bolt into and keep tightening the bolt in it will push the drum off.
Once inside there is a wheel cylinder which pushes out each side to move the brake shoes into the drum at the top. If you could wire the shoes together at this point you could keep from dragging the brakes. The leaking could be from the wheel cylinder going bad - they are cheap ($20) and easy to replace. The noise you describe sounds like the wheel nut is not torqued properly. There is a tapered washer behind the wheel nut that holds the bearing in place. If it is not set right the rear end makes noise like you describe - and it is more noticeable at low speed and coming to a stop. subaruparts.com doesn't have a diagram for the drum brakes check out this site http://wac.addr.com/auto/obs/disc/disc.html |
#11 |
Member#: 25008
SCIC
Vehicle: orginially founded by Germans... |
get regular brakes!
zing |
#12 |
Member#: 16615
Vehicle:I ♥ my TE51 2009 Nissan 370z |
you can't remove the drum. when you step on the brakes, the slave cylinder is going to break, because there is nothing to stop it from expanding (shoes against drum) and you'll have no brakes at all.
Whos cares about the noise. as long as it stops the car, just drive it to the shop. Undo the E-brake, pull the drum off (you may need two bolts to force the drum off) and just make sure everthing looks intact. I'm guessing the noise is from your shoes being worns down to the metal (wear indicators). P.S. jesus you're ****ing dumb. stop calling people n00bs, because you've been on here since 1999 and you haven't learned a thing. |
#13 | |
Member#: 191
NESIC
a little rage problem there buddy? Want a hug? |
#14 |
Member#: 16615
hug would be nice. thank you.
#15 | |
Trust no one
Ok, in most cars the drum will just pull off when the wheel is removed, perhaps these are different. It should be obvious with the wheel off if there is anything else holding the drum in place.
#16 |
Member#: 16615
you don't have to remove the nut to just remove the drum.
#17 |
Member#: 1711
South East
I''m assuming this car is awd - is it not?
#18 |
Member#: 16615
fwd
#19 | |
Member#: 1711
South East
#20 |
Member#: 1711
South East
fwd? damn keif - what kind of ***** are you?
**** it - I ain't giving anymore help to someone who's been around since 99 and still buys a 2wd suby you're right - he learned nothing. ![]() Last edited by immortal_suby; 06-27-2004 at 03:04 PM. |
#21 | |
Member#: 16615
#22 |
Member#: 1711
South East
relax - I'm only kidding around.
there - I threw a stupid tongue out smiley guy in there to denote sarcasm |
#23 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
keith is a n00b and im gonna beat him with a drum brake when he gets to NJ...
so did you take the drum off yet or what? I bet the shoes are worn out and grinding against the drum... Jay |
#24 |
Member#: 191
NESIC
FIGHT!!!!
hey, its not only fwd, but its an automatic! OHH YEAH!!! ![]() (only for another week..then its a 5speed )either way guys, thanks for the ideas. I went out to play with the brakes and ended up taking out interior parts instead only thing left is the dash, front seats, and front door cards....I figure that by throwing out all the other stuff, I can stop the car using my feet.![]() ehhe (2000 RS interior being installed) Tomorrow I play with the brake. If all else fails....I'm just going to kick it. THanks again guys Matt, the hug is $10, I take paypal Keith |
| Thread Tools | |
| Display Modes | |
| Anybody need a Realtor? I need to fix my FXT | roloc31 | Rocky Mountains Impreza Club Forum -- RMIC | 19 | 12-06-2009 03:29 AM |
| So I need to paint my rear armrest cover black, suggestions | Gso2k | Interior & Exterior Modification | 0 | 04-24-2008 12:44 AM |
| I need to fix my brakes! Anyone want to make some money? | robsta1 | Southern California Impreza Club Forum -- SCIC | 7 | 04-11-2008 06:33 PM |
| I need to fix my fridge next - leaky! | sonicblue | Off-Topic | 7 | 04-07-2008 12:30 PM |
| School me on Catholic Baptism. I need to fix my mother in law's wagon! | WarWagonPA | Off-Topic | 23 | 04-17-2006 09:33 PM |
