Old 01-02-2001, 01:05 PM   #1
IMPBOY
Member#: 65
Post J&S Q's (tried the search already)
Just want to make sure, I connect the ignition control wires B134 #25 (cyclinder 1 & 2) and B134 #26 (cylinder 3 & 4) right?
I have 00 but the instruction is for 99 coil pack w/ internal ignitor. The ignition system for 00 and 99 are same right?
IMPBOY is offline   Reply With Quote
Old 01-02-2001, 04:09 PM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Post
It should work. Just don't cross them at the J&S. The worst that can happen is the engine not firing.
-WaC
Wayne
wac is offline   Reply With Quote
Old 01-02-2001, 05:00 PM   #3
IMPBOY
Member#: 65
Post
One another thing, the instruction has yellow for out 1 and white for out 2 but the J&S it's yellow for out 1 and BROWN for out 2. I should connect the wires according to right port indications regardless of color of the wires right?
Was this the case for any of you guys?
Old 01-02-2001, 06:44 PM   #4
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Post
Yes, ignore the wire colors if they don't match the drawing. Did someone change it on you? If possible, you should either rearrange the wires to match the drawing, or mark up the drawing so you don't get confused later.
I got both of my J&S units used, and each had a little different wiring. But the wire terminals on the boxes were identical for both.
-WaC
Wayne
Old 01-02-2001, 09:40 PM   #5
IMPBOY
Member#: 65
Post
Yea, mine was used too. Thanks for your help.
v.1 or v.2 accessport (yes i've searched already) RS25scooby AccessPort 9 05-27-2008 10:59 PM
P0244 code problem(I've searched the forums already) dubluv17 AccessPort 17 05-17-2007 12:21 AM
VF30 / MBC owners - please help. (Yes i tried the search for like an hour) rayder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-02-2002 12:15 AM
Stromung Exhaust ? - NO it's NOT in the search, I tried... sorny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 10-10-2001 11:19 AM
Tried a search, anyone have pics of the rally mustang? ChosenWon Motorsports 10 06-22-2001 03:35 AM
