Old 10-16-2000, 10:53 AM   #1
Eddie
Member#: 1123
Post plug wires???
I hit the 30,000 mark and it's time to tune up. I'm gonna be changing to the denso iridium plug but where can I get a godd set of wires?
Eddie is offline   Reply With Quote
Old 10-16-2000, 11:01 AM   #2
XT6Wagon
Member#: 524
04 STi
Post
This may sound sad, but if pepboys wires are 8mm and fairly new, they are the best wires for the $$ I have found. If they are 7mm don't get them.
I have had a little bit of trouble with the wires that had been on the shelf for 3-4 years though so watch that.
XT6Wagon is offline   Reply With Quote
Old 10-16-2000, 11:19 AM   #3
PeterPan
Member#: 1613
99 Impreza 2.5RST
Silver Thorne
Thumbs up
The TecII kit uses magnicore wires. so they have to be good right. try and search the internet for them.
PeterPan
PeterPan is offline   Reply With Quote
Old 10-16-2000, 11:54 AM   #4
Joel Gat, 1.8L
Member#: 32
Post
Hello,
MAgnecors are the gold standard that all other wires should be compared to. They cost about $80 for a set and like the ads say, don't expect a power gain from Magnecors. They tell it like it is, no wires give more power unless compared to bad wires that were robbing power.
That all being said, NGK (blue) wires are pretty damn good and are half the price
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Old 10-16-2000, 12:19 PM   #5
adam99rs
Member#: 20
Post
...and they fall off! for my $80, they should at least stay on!
Best bet...make your own, using Accel', MSD's, etc.
The iridium plug is a whole other issue.
adam99rs is offline   Reply With Quote
Old 10-16-2000, 02:08 PM   #6
PeterPan
Member#: 1613
99 Impreza 2.5RST
Silver Thorne
Post
Good Good Good.
PeterPan
Old 10-16-2000, 07:15 PM   #7
Eddie
Member#: 1123
Wink
What's wrong with the iridium plug? I'm not expecting more power out of changeing the plugs and wires I just want the cleanest best spark possible for my subie.
Old 10-16-2000, 07:22 PM   #8
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Then get plain NGK copper plugs and replace them every 10,000 - 15,000 miles. Performs great and it's a lot cheaper, even buying 5 sets to one.
[This message has been edited by ColinL (edited October 16, 2000).]
ColinL is offline   Reply With Quote
Old 10-16-2000, 08:33 PM   #9
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Post
The site is http://www.cyberauto.com Ask them for a quote. The last quote
they sent me was for $66.52 about a year ago so the price may have changed.
the part number is Manger KV85 Competition Spark Plug Wires #45350. It took me a few weeks to get them.
Pics of the wires installed in the Misc pics of the Mods section here:
http://www.azscooby.com/
Peaty is offline   Reply With Quote
Old 10-16-2000, 09:52 PM   #10
george
Member#: 2605
2000 Impreza 2.5 RST
Blue Ridge Pearl
Question
I know they're pretty expensive but, what do you guys think of the 9mm Sparkco wires?
george is offline   Reply With Quote
Old 10-17-2000, 01:51 AM   #11
PeterPan
Member#: 1613
99 Impreza 2.5RST
Silver Thorne
Post
Waht do you mean they fall off.
Peter Pan
Old 10-17-2000, 01:52 AM   #12
Joel Gat, 1.8L
Member#: 32
Post
Hello,
Adam, the ones that fall off are the ones that were designed off Alex's wires Too short! Magnecor rectified the situation already quite some time ago.
Joel (who agrees on the plugs being a different issue worthy of another thread)
Old 10-17-2000, 09:25 AM   #13
adam99rs
Member#: 20
Post
I don't know Joel -I have the 'redesigned ones" too, and had the same problem. after some hard launches, or rough roads (I occassonally take mine off road), the #4 and #3 plugs on the cylinder side fall off. Both times, i bunred holes in the insulation from the arcing.
As for the iridium plugs, I just have my own opinions of them. I tend to just looka twhat the racers use, and go from there. I have tried the iridium ones in my ZX, which serves as a test bed for various new items on the market, in hopes of every extra 1/0th or extra 1mph. Bottom line is I played with the entire heat range set of the HKS's, and they worked no better nor no worse than the regular NGK's I have always used so i stuck with them (much, mcuch cheaper to0). I am not saying what you should or shouldn't get, just my opinion.
as for wires, on the subaru, I am sticking with the stock ones...work just fine, and are cheap enough to replace. if I ever feel the ned for new ones, I will make my own set o MSD's, which i hapen to like the connectors on (i.e. they have yet to fall off!)
Old 10-17-2000, 10:32 AM   #14
Rajah
Member#: 362
2006 WRX STi
WRB / Gold
Thumbs up
Gonna have to agree with Adam - the $80 set of Magnecore's are a waste of money, IMHO. I saw no improvement over the stock wires. Stick to the stockers, and if they need replacement, go NGK! (Always go NGK! )
Rajah is offline   Reply With Quote
spark plug wires/ plugs reality1011 Normally Aspirated Powertrain 30 02-27-2010 11:09 AM
FS: STi spark plug wires for non-coil-on-plug turbo engines Necromancer VIC Private Classifieds 6 09-20-2009 01:35 PM
Can a check engine light be caused by bad spark plugs or bad plug wires? pico Newbies & FAQs 7 06-27-2002 05:57 PM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 05:17 AM
Sparg Plug wires and plug question sparco Normally Aspirated Powertrain 4 02-13-2002 02:41 PM
