Old 06-27-2004, 03:14 PM   #1
KnightWRX
Member#: 41664
black
Question 18X7.5 with 42 offset ok?
The ones im looking at are ADR flights in an 18X7.5 rim with 42 offset. They are listed as fitting the WRX but with offset's on our cars I wanted to make sure...hehe
KnightWRX is offline   Reply With Quote
Old 06-28-2004, 03:29 AM   #2
BurtonCR
Member#: 7138
Its definitely not the best. Basically you create loads that your suspension and hubs were not designed for, so you wheel bearings might go sooner or the tires will rub. Im sure 42mm offset isnt unheard of, its just not the best considering there are plenty of rim choices available in 48mm +.
- Chris
BurtonCR is offline   Reply With Quote
Old 06-29-2004, 02:23 AM   #3
STi FSU
Member#: 61740
'04 STi Blue
Fast
If you have to have them, then, by all means they will be fine. You may have fender rubbing issues in the rear and may need to roll them or increase camber, depending on the suspension setup and alignment.
FSU
STi FSU is offline   Reply With Quote
Old 06-29-2004, 12:38 PM   #4
subieworx
Member#: 47769
They should fit fine, but it will be close. I would worry about the wheel bearing wear as you are only moving the wheel out by an average of aobut 6mm.
subieworx is offline   Reply With Quote
5x100, 18x7.5, +48 Offset VS 18x7.5 5x100 +53 offset rohchris Interior & Exterior Modification 10 08-16-2009 04:34 AM
18x7.5 with +42 offset ok ? wrxsubaruwrx Tire & Wheel 9 02-19-2006 01:00 AM
Will an 18x7.5 w/ 42 offset fit??? HELP ASAP!!! Jaredm83 Tire & Wheel 1 03-04-2005 12:58 PM
18x7.5 w/ 42 offset shaneswrx Tire & Wheel 3 08-19-2004 01:17 PM
My 17X7 work meisters might be recalled might consider the 18x7.5 with a 45 offset. scootr Brakes, Steering & Suspension 1 04-23-2001 11:58 PM
