Old 06-27-2004, 05:11 PM   #1
BHawk
Member#: 61860
2004 WRX STi
Default Will Kumho MX 255/40R17 fit the 04 STi stock rim?
I am considering a differen't tire size next time I need new tires. I would like to up size the width, but not the overall diameter of course. I am considering Kumho MX 245/40R17 or 255/40R17. Anybody have any idea if either of these will fit?
BHawk is offline   Reply With Quote
Old 06-27-2004, 11:22 PM   #2
ripvw
Member#: 27790
according to Kuhmo, you need an 8.5" wide wheel for 255/40x17
235/40x17 = 8" minimum (but the MX doesn't come in this size)
245/40x17 = 8" minimum
245/45x17 = 7.5" minimum but it's kind of a tall tire - lots wider than a 225 however...
ripvw is offline   Reply With Quote
Old 06-27-2004, 11:44 PM   #3
rich728
Member#: 40328
2004 WRX STi
BSP #728
Dont think that will work. 235 is the widest that will fit our 7.5" rims.
BTW BHawk is your STi wingless?
rich728 is offline   Reply With Quote
Old 06-28-2004, 12:31 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I'd do the 245/40's on an 8" wheel...
Old 06-28-2004, 01:59 AM   #5
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I've heard that it will fit, but honestly, it's not a good fit.
Stick with 225/45 until you get 8" wheels.
nhluhr is offline   Reply With Quote
Old 06-28-2004, 05:07 PM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
That's easy.
No.
mav1c is online now   Reply With Quote
Old 06-28-2004, 09:09 PM   #7
del105
Member#: 43010
1974 2002tii
Yes they will fit. I guarantee anyone that says no in this thread has not even tried to fit them. The 255/40/17 would be my choice because you will keep factory tire height. They will also fit fine on a 7.5" wheel.
del105 is offline   Reply With Quote
Old 06-29-2004, 02:07 AM   #8
STi FSU
Member#: 61740
'04 STi Blue
Fast
Yes it will fit, and has been done before. But I certainly would not not recommend doing it. Feel free to try it and let us know how it compares to stock.
I currently run 255/40-17's on 17x9/8.5" F/R. I wouldn't even put a 255 on a 17x8.5 on the front of the car, it's pulled in to far for a tall tire. My other set is 245/40-17 on 17x8.5.
FSU
STi FSU is offline   Reply With Quote
Old 06-29-2004, 09:02 AM   #9
Tire Rack Moderator
Member#: 1215
ext. 4362
while you can physically put the tire on the wheel it will not perform very well and the contact patch would be smaller than you would expect because the sidewalls are so, pinched in ..... and in order to reduce the extreme sidewall deflection it would cause you will have to run very high air pressure further reducing the contact patch and causing irregular wear
Old 06-29-2004, 10:16 AM   #10
mav1c
Hoodbridge!
Member#: 560
OK....sure....I suppose you could FORCE the tire on, but it'd be a waste of time and money for all the reasons Luke stated.
Old 06-29-2004, 11:00 AM   #11
del105
Member#: 43010
1974 2002tii
but it still will have a larger contact patch than the 225.
The only reason I can see for adding a larger tire is for racing and sometimes you're limited by the size of the wheel and ever bit helps. I don't really see the point in running a larger tire on the street though.
Old 06-29-2004, 11:54 AM   #12
mav1c
Hoodbridge!
Member#: 560
Doubt it. The sidewalls will be so pinched in the tread surface will become rounded. (like a motorcycle tire). Plus the tire will squirm a lot because the sidewalls will be at such a severe angle.
Just because it will fit on the rim, doesn't mean it's better. There's a reason why tire manufacturers have recommned wheels widths for differrent size tires.
05 sti lateral link will they fit the 04 sti? gtasti Brakes, Steering & Suspension 10 01-25-2008 01:59 AM
Will 275/40-17 V710's fit an 04 STi on stock suspension? polyol Motorsports 7 03-10-2007 12:28 AM
does 06 STI rims fit the 04 STI spyoptic10 Tire & Wheel 8 01-21-2007 04:32 PM
Any 16 inch rims will fit the 04 STi? V6 Tire & Wheel 5 08-05-2005 04:12 PM
Do these rims fit the 04' STi stock tires? sumkee Tire & Wheel 7 06-19-2005 05:07 PM
