Old 10-15-2000, 10:48 AM   #1
Siper2
Member#: 1134
2007 BMW 328xi wagon
Question What model NGK plug to replace with?
Well I just read a few posts on here, and looked about the 'Net and saw that yes indeedy, George, lots of Scoobyfolk replace the stock Champion (or whatever) plugs with NGK.
Now.... these are copper replacements, I'll assume? Anyone know the model number?
Now I know I've got a plug ratchet in my house somewhere.
-S2-
Siper2 is offline   Reply With Quote
Old 10-15-2000, 11:41 AM   #2
Camaroman
Member#: 1559
2004 Sierra Denali
Post
I just put in the Bosch +4 platinum plugs in friday
Camaroman is offline   Reply With Quote
Old 10-15-2000, 01:47 PM   #3
george
Member#: 2605
2000 Impreza 2.5 RST
Blue Ridge Pearl
Post
I've got them right here in front of me.
NGK VX (Platinum)
Part# BKR6EVX-11
Stock No. 3540
If you'd like I'll sell them to you, since I changed my mind of changing my spark plugs.
george is offline   Reply With Quote
Old 10-15-2000, 01:48 PM   #4
edekker
Member#: 143
1999 Impreza 2.5RS
Supercharged - and STOLEN
Post
Siper2,
If your stock Champions were RC10YC4 (as mine were), then the NGK equivalent is BKR5E-11.
Ed.
edekker is offline   Reply With Quote
Old 10-15-2000, 02:05 PM   #5
Siper2
Member#: 1134
Post
Okay guys so there's more than one platinum plug that'll work? Oh great, how wonderfully confusing. I figured y'all would be going to copper plugs...
Thanks for the offer to buy them, but I'll just get them up here whenever I make up my mind. Not sure yet, so...
Why the switch, I mean do the stock ones suck or what?
-S2-
Old 10-15-2000, 02:16 PM   #6
george
Member#: 2605
Blue Ridge Pearl
Post
I believe our cars already come with platinum plugs. My dad just convinced me not to change them yet... that's why I offered to sell them to you.
BTW I'm pretty sure these are the right plugs for MY00 RS.
[This message has been edited by george (edited October 15, 2000).]
Old 10-15-2000, 02:41 PM   #7
edekker
Member#: 143
1999 Impreza 2.5RS
Post
Siper2,
For the record, my stock Champions were copper. My posted NGK equivalent is also copper. The copper plugs, which are low cost, will work as well as the platinum ones, but they will not last as long.
If you are interested in only the platinums, then go for the NGK BKR5EVX-11. NGK also make double platinums (last even longer) at a relatively high cost.
Check your heat range. If the Champions are 10, then get the NGK 5. For a 9, get the NGK 6.
Ed.
[This message has been edited by edekker (edited October 15, 2000).]
Old 10-15-2000, 04:22 PM   #8
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Copper conducts better than platinum, but doesn't last nearly as long. But that's not that big an issue since copper plugs are so cheap & they're easy to swap.
Some MY98's came with platinum NGK's, everything else had copper Chumpions.
The equivalent NGK plugs are listed in the owner's manual.
RidinLow is offline   Reply With Quote
Old 10-15-2000, 04:50 PM   #9
edekker
Member#: 143
1999 Impreza 2.5RS
Post
Personal opinion ...
Copper, platinum, iridium alloy, whatever - the electrode will conduct way-the-hell better than the spark plug's built-in resistor. Don't worry about the metal's conductivity when choosing your spark plug.
Ed.
Old 10-16-2000, 04:42 AM   #10
Siper2
Member#: 1134
Post
So is this going to be any kind of a worthwhile swap? I haven't checked to see what's in my car yet, probably do it tomorrow. I don't have a torque wrench or anything, so "in tight" is as good as the plugs'll get.
-S2-
Old 10-16-2000, 07:24 AM   #11
edekker
Member#: 143
1999 Impreza 2.5RS
Post
Siper2,
Don't change the plugs unless you can do it properly.
Your comment worries me and tells me you've had little experience or have been misinformed about installing spark plugs. Install them too loosely and you'll get gas blow-by. Install them too tightly and you risk stripping the threads, or damaging the ceramic insulator and the glass-to-metal seals, compromising heat extraction capabilities and the spark plug's overall integrity.
Install the plugs first by hand – making sure you are not cross-threading them. Get a torque wrench, if you're serious about this. The plugs need to be torqued 18 to 22 ft-lbs.
You are not really going to see an improvement in performance unless the old plugs had been worn down. If your plugs are fine, leave them alone. But if you want to extend the service life, get the platinums. If you think switching to platinums will get you more power, you will be disappointed, placebo effect notwithstanding.
Ed.
Old 10-16-2000, 08:30 AM   #12
sanders
Member#: 187
2008 Impreza 2.5i
NBP
Post
i didn't believe it when i read the box... but it said gas mileage will be improved with the DENSO IRIDIUM plugs... but i put them in anyhow, and i did notice a greater increase in gas mileage... from 280 to 377 miles on a full tank... i'd recommend them.
sanders is offline   Reply With Quote
Old 10-16-2000, 08:35 AM   #13
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Post
A 100 extra miles just by changing your plugs? That's crazy! How 'bad' where the plugs you pulled out? <----I don't really know how u can answer this but I thought I'd ask.
Kevin Thomas is offline   Reply With Quote
Old 10-16-2000, 09:05 AM   #14
Siper2
Member#: 1134
Post
edekker,
Much experience? No. But I know how to use common sense. No insult to you, I just think you're misjudging.
Obviously one can't cross-thread a plug. Years of riding '80s snowmobiles taught me how to take a plug in and out. Many times.
As for putting them in too loosely, I know about blowout. Had it happen on an old car of mine. Not that it matters, but it wasn't me who installed them.
-S2-
Old 10-16-2000, 09:05 AM   #15
edekker
Member#: 143
1999 Impreza 2.5RS
Post
sanders,
Denso doesn't tell you the conditions under which the improvement is realized.
If you're starting out with worn plugs, the improvement will be realized with new plugs – any plugs.
If you're ignition system is weak; an improvement may be realized with the Denso since the center electrode diameter is so small and pointy. For a given gap, one with a pointy electrode will require a lower high-tension voltage to initiate a spark. If you see an improvement with the Denso then I would question the health of the ignition system.
Just my opinion,
Ed.
Old 10-16-2000, 09:09 AM   #16
Siper2
Member#: 1134
Post
Oh one more thing... No I'm not looking for more horsepower. But this seems to be a common modification, and if it makes the engine happier, I'll do it. I was asking if it's copper vs. platinum because most folks prefer copper. Platinum has a longer life, but copper's spark seems to agree with the performance crowd.
-S2-
Old 10-16-2000, 09:25 AM   #17
sanders
Member#: 187
2008 Impreza 2.5i
NBP
Post
wassup?
i also added an apexi safc... and i've been playing around with it... i'm not too much of a tech... but i know... i got a crap load more miles on a full tank!
edited part: as for my stock plugs... 24K miles with them... they were brownish/black... hehehe...
--chad--rs
[This message has been edited by sanders (edited October 16, 2000).]
Old 10-16-2000, 09:54 AM   #18
DuneHopper
Member#: 1249
2000 OBS
Thumbs up
I replaced the stock Chumpians with copper NGK's last week (at 13K miles on a MY00). I'm skeptical, but my putt-putt OBS seemed to have gained more gumption than can be accounted for by just the ECU reset that I did concurrently (I've reset the ECU before). I didn't think plugs could make that much of a difference, but my butt-dyno says otherwise.
There was a great thread on the practical parts of changing plugs a week or two ago.
DuneHopper is offline   Reply With Quote
Old 10-16-2000, 10:48 AM   #19
Rajah
Member#: 362
2006 WRX STi
WRB / Gold
Thumbs up
I hear ya.. there's nothing quite like new plugs.. mmmm.. ... well, I guess a new turbo would suffice.
Rajah is offline   Reply With Quote
Old 10-16-2000, 11:00 AM   #20
Joel Gat, 1.8L
Member#: 32
Post
Hello,
Scoobie Newbie wrote "Bosch plugs in anything European, AC's in anything American".
While that makes sense, I've noticed that NGKs work just great in american cars, too They're just special order part numbers for everyone since, as one grease monkey said "thems for jap cars." We stuck 'em in, used 'em for 10k miles, and pulled 'em out and they seemed to have retained their gap distance better and the car ran perfectly happy with them... The ACs wore out faster (gap widened more, more carbon buildup, etc.).
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Which NGK plugs to go with? 05wrx09 Service & Maintenance 36 05-26-2009 05:01 PM
Stock rims suck. What to replace with stock wheel for WRX? IceWind Tire & Wheel 12 12-21-2005 01:59 PM
What to replace with a new Timing Belt? beanders Engine Management & Tuning 3 09-25-2005 01:27 PM
What to replace with clutch plate? LIFEFORM Transmission (AT/MT) & Driveline 4 04-20-2005 04:03 PM
Which NGK plug to get? EJ205rulezall Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-29-2004 01:37 PM
