Old 06-27-2004, 11:29 PM   #1
fosgate769
Member#: 55841
2007 STi
WR Blue
Default Rim Width
Will be getting a new set of wheels soon. Going with the SSR comps and a BFG KDW tire. Having a problem settling on the size. I really like the look of a 245 size tire but not sure if it will rub. On tirerack if you look up a 2003 wrx the rim are 17X7.5 and i dont think a 245 tire would fit anyway. But if you put in an STi They have 17X8.5. Will these rims fit good on my car, and will the 245/40-17's fit on that rim w/o rubbing. Stock supension. I would think that combo would fit with the right offset and not cause problems, although tirerack does not list the offset of these wheels, anyone know?Sould i try for the wider tire or play it safe with a 17X7.5 wheel and 225/45-17 tires?Please if anyone has info or is running a set up like this let me know thx.
fosgate769 is offline   Reply With Quote
Old 06-27-2004, 11:44 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Talk to Luke He's da man
Old 06-28-2004, 12:09 AM   #3
ripvw
Member#: 27790
The 17x8.5 SSR's are ET48
Lots of people run 17x8 ET48 Rotas on WRX sedans and with 235/40x17 there is no rubbing with moderate lowering
However, the 17x8 and 245/40x17 combo will rub on the sedan, so I'm pretty sure that even at stock height the 17x8.5 will require you to roll the fenders
ripvw is offline   Reply With Quote
Old 06-28-2004, 12:14 AM   #4
El Supremo
Member#: 38388
Default ssr comps
I'm running SSR Comps (17x7.5) and Toyo Proxes 225/45-17 on my 2002 WRX wagon. There are rubbing issues on the wagon with wider tires and rims. As you stated, I also went the safe route. I'm also 3 LBS lighter than stock on each wheel. Many have had their fenders rolled ($300.00+/-) and now run larger widths with no problems. However, I didn't. For now, the above combination holds the road fine. The rims are forged and strong and the tires are sticky
Supremo
El Supremo is offline   Reply With Quote
Old 06-28-2004, 10:09 AM   #5
Tire Rack Moderator
Member#: 1215
ext. 4362
I have seen 245's cause some rubbing issues that couldn't even be corrected with a fender roll ...... 235's is about as wide as I would recommend
Old 06-28-2004, 12:00 PM   #6
subieworx
Member#: 47769
It all depends on the camber of the rear wheels. If you run pretty close to 0 you will have rubbing issues even with the fenders rolled. If you run closer to -1.5* you will still have to roll the fenders, but should not encounter any further rubbing issues.
subieworx is offline   Reply With Quote
Old 06-28-2004, 01:21 PM   #7
fosgate769
Member#: 55841
2007 STi
WR Blue
Ok will be ordering today going to go with the 225 Thx for the info. By the way seen a lot of post about rolling fenders was wondering exactly how you would do that, not that im going to just wondering.
Old 06-28-2004, 01:28 PM   #8
subieworx
Member#: 47769
Basically bend the fender lip up so that it is flush with the fender itself.
Old 06-28-2004, 07:51 PM   #9
Ulf Wafflestein
Member#: 36163
2012 Focus Hatch
Sonic Blue
has anyone tried an 8 or 8.5 inch wheel with something like the chargespeed fenders which are a little wider than stock? Is the extra 20 mm in width enough to make a 245 tire not rub you think?
Ulf Wafflestein is offline   Reply With Quote
Old 06-28-2004, 08:59 PM   #10
subieworx
Member#: 47769
20mm is almost an inch of extra room which would be more than enough.
Old 06-28-2004, 10:04 PM   #11
Ulf Wafflestein
Member#: 36163
2012 Focus Hatch
Sonic Blue
hmm, I forgot how much 2 cm is.
Old 06-29-2004, 12:45 AM   #12
subieworx
Member#: 47769
2.5cm=1"
Old 06-29-2004, 09:34 PM   #13
wRx14pSi
Member#: 6203
but the charge speed fenders are for the fronts only..
So the front would clear the 8.5 245 series setup..
what will you do about the rears??
wRx14pSi is offline   Reply With Quote
Old 06-29-2004, 10:45 PM   #14
Ulf Wafflestein
Member#: 36163
2012 Focus Hatch
Sonic Blue
I'm hoping since they don't have to turn that I'll be ok since I'm still at stock ride height. If the fenders need to be rolled I'm sure it wouldn't be a problem for the body shop to give it a few whacks with teh hammer since my car will be in there for basically a whole front end, sans 1 headlight and the hood scoop
Old 07-05-2004, 10:50 PM   #15
fosgate769
Member#: 55841
2007 STi
WR Blue
Wheels and tires came in got pics up check them out tell me what ya think.
PICS here
Old 07-05-2004, 11:08 PM   #16
TGITI
Member#: 63365
02' WRX Sedan
COBB Stage 1
Looking Sweet Fosgate!
TGITI is offline   Reply With Quote
Old 07-05-2004, 11:08 PM   #17
El Supremo
Member#: 38388
Good,
I've got the ssr comps 225/45-17's on my blue 2002 wagon with Toyo Proxes tires. They look good on a b;ue vehicle, however some of the clear coat is chipping off.
Supremo
Rim Width issue, will a 9.5'' rim fit? enigma94 Tire & Wheel 10 10-29-2007 08:47 PM
Max optimal tread width to rim width chart? chimchimm5 Tire & Wheel 2 01-13-2007 12:27 AM
A question regarding max rim width for 18" rims for my 02 wrx wagon davejread Tire & Wheel 0 06-16-2004 05:29 PM
Tire width and rim width numbers? Any resources? ciper Brakes, Steering & Suspension 5 07-23-2002 11:43 PM
rim width, off set??? need help littleblue Brakes, Steering & Suspension 3 05-01-2001 01:31 AM
