Old 06-27-2004, 11:08 PM   #1
rich728
Member#: 40328
2004 WRX STi
BSP #728
Default Looking for pics of a 235/40/17 tire on 7.5 STi wheel
Searched and came up with nothing.
rich728 is offline   Reply With Quote
Old 06-28-2004, 10:43 PM   #2
rich728
Member#: 40328
2004 WRX STi
BSP #728
Old 06-29-2004, 03:10 AM   #3
YinUCSD
Member#: 44945
05 Fxt
black
i'd like to see also. or if anyone tried it, how they compare to stock size 225-45-17. ie, is it worth it?
YinUCSD is offline   Reply With Quote
Old 06-29-2004, 08:31 AM   #4
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
minimum wheel width for a 235/40-17 = 8.0"
2004 STi wheel width = 7.5"
Old 06-29-2004, 08:50 AM   #5
rich728
Member#: 40328
2004 WRX STi
BSP #728
but people have made them fit
Old 06-29-2004, 09:04 AM   #6
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
while you can physically put the tire on the wheel it will not perform very well and the contact patch would be smaller than you would expect because the sidewalls are so, pinched in ..... and in order to reduce the extreme sidewall deflection it would cause you will have to run very high air pressure further reducing the contact patch and causing irregular wear
Old 06-29-2004, 12:04 PM   #7
rich728
Member#: 40328
2004 WRX STi
BSP #728
damn....that makes sense. I in a tough spot. I was able to pick up some new Goodyear Eagle F1 GS-D3 235/40/17 at a good price and want to put them on my stock rims.
Old 06-29-2004, 12:47 PM   #8
YinUCSD
Member#: 44945
05 Fxt
black
ive heard enough from the pro's about 225-45-17 still being better than 235-40-17 (on 7.5" wide rims) that it makes me want to stick with 225-45-17 and not mess with anything.
e35 18x8.5 w/ 235/40/18 Tires on 06 CGM STi suby_dude Tire & Wheel 10 09-16-2007 12:56 PM
HELP 235/40/17 Tires on stock 04 STI rims fastXT04 Tire & Wheel 12 07-20-2005 05:45 AM
Is it okay to mount 235/40/17 tire on a 17/7.5 wheel?? WRXinEffect Tire & Wheel 17 05-30-2005 08:56 AM
does 245/40 17 tires on 7.5" wide wheels = trouble, or < optimal performance? rex n effect Brakes, Steering & Suspension 10 02-10-2003 10:35 AM
does anyone have 235/40 17 tires on 7.5" wide wheels? rex n effect Brakes, Steering & Suspension 0 02-03-2003 01:22 AM
Message Board Statistics All times are GMT -4. The time now is 02:24 PM.
