Old 10-14-2000, 01:04 AM   #1
samurai
Member#: 696
2005 WRX STi
Post Front LSD ? Is it a direct bolt on??
Hi guys! I had a question about the front LSD that Sti sells. Is it a direct bolt on to our 2.5RS?
I guess I'll mod first things first and start with the Sti/Spt short throw shifter I just got in the mail!
Anyways, I'd appreciate it if somebody had an answer to my question.
Tim
samurai is offline   Reply With Quote
Old 10-14-2000, 02:00 AM   #2
Joel Gat, 1.8L
Member#: 32
Post
Hello,
The WRX front diffs do fit the US tranny. However, you need to change a couple things, including the stub axles, according to Trey. Now, "bolt-on" is another question... If tearing apart a transmission is "bolt-on" then you are a vastly superior mechanic than I am I consider tearing the tranny apart about the biggest pain in the butt thing you can do on a car, second to rebuilding an engine, which I just recently finished and will likely never tackle again... the time it took me, I could have paid someone and then made the money up working and still had time to spare
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Old 10-15-2000, 09:35 AM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I would not install a clutch-type mechanical LSD in the front unless you spend a lot of time offroad. A better choice would be a Quaife (torsen). Quaife would also be a good choice for the rear diff, again unless you are rallying. I get the feeling most of us are the tarmac sort.
ColinL is offline   Reply With Quote
:::PROOF::: that a V8 STI Intercooler is a DIRECT BOLT ON on to 04-05 WRX!!! shinsain Factory 2.0L Turbo Powertrain 82 11-26-2010 12:30 PM
is the 04 sti rear hubs a direct bolt on to my stock 03 wrx? Subadubaru Transmission (AT/MT) & Driveline 3 11-17-2009 02:02 AM
Is IHI VF34 Turbo Direct bolt on to Subaru WRX STI ver 6 (GC8 JDM Model) viraju Factory 2.0L Turbo Powertrain 24 06-14-2009 02:16 PM
Is the VF 22 a direct bolt on on the STI ?? carguy19 Factory 2.5L Turbo Powertrain 4 01-12-2004 09:22 PM
Does anyone know if this is a direct bolt-on to a USDM 2002 WRX? MK2TMR2 Brakes, Steering & Suspension 1 04-26-2003 09:35 AM
Message Board Statistics All times are GMT -4. The time now is 06:41 PM.
