Welcome to the North American Subaru Impreza Owners Club Friday July 25, 2014
Old 02-09-2001, 09:20 AM   #1
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Question Clutch Disc vs. New Clutch
I own a 97 GT and have noticed the clutch is starting to slip. I've noticed that Cobb Tuning sells the ACT clutch for ~$400 while SPO Motorsports advertises a clutch disc replacement for ~$150. My question is whether I can get away with just replacing the clutch disc and using the old stock pressure plate or do I have to change the whole clutch in its entirety.
Obviously, I'd rather keep cost to a minimum, so any other suggestions are welcome.
Thanks,
Jason
2.5GT is offline   Reply With Quote
Old 02-09-2001, 01:52 PM   #2
Aspen
Member#: 145
Banned to
Housework for Summer
Post
If you're still normally aspirated and don't have many mods than you can just replace the clutch disc assuming your pressure plate is in good condition. Look for deep scoring marks around the finger area of the pressure plate.
The ACT clutch set uses the stock Subaru clutch disc(same part#'s) and you should be able to get one under $100 for the disc alone from Lisa at Troncalli Subaru(aka Sugar).
You can send me the $50 that you just saved.
Aspen is offline   Reply With Quote
Old 02-09-2001, 04:13 PM   #3
Tangmere
Member#: 572
Post
Chances are the reason your clutch is slipping is due to the fact that the pressure plate is losing its clamping force, hence, the cluch slips. Either way, regardless of the brand you choose, replace both as a set (including the throwout bearing)
Tangmere is offline   Reply With Quote
Old 02-09-2001, 07:20 PM   #4
Miracle Worker
Member#: 1390
2000 2.5 RS Sedona
Red (Chicken Katcher)
Post
I just had my other cars clutch go and I found out that it is better to get the clutch kit {Clutch/plate/bearing}. Getting one and not the others may leave you with taking the whole thing apart a few thousand or hundred miles later.
Miracle Worker is offline   Reply With Quote
WRX clutch Cylinder vs STI clutch Cylinder kakarotoni Newbies & FAQs 8 12-02-2010 03:24 PM
FS Clutch disc (only) NEW $60 jackansi Drivetrain 1 08-20-2009 12:24 PM
Replace Clutch Disk or New Clutch Kit? Ali_WRX Transmission (AT/MT) & Driveline 4 03-02-2009 12:56 PM
Slipping clutch issue.. with new clutch kit, evsoul Transmission (AT/MT) & Driveline 7 09-05-2006 01:39 PM
Clutch problem with new clutch Evaider Transmission (AT/MT) & Driveline 17 04-27-2002 05:58 PM
