Old 12-17-2000, 07:33 AM   #1
AccidenT
Member#: 2024
2005 Legacy 2.5i
Atlantic Blue Pearl
Post Me vs. Weapon*R intake round 2
If you're wondering what round 1 was, I detailed it here: http://www.i-club.com/ubb-files/Foru...ML/000644.html
I have since purchased everything necessary to answer my questions from that post. However, I have a new one, and it goes a little something like this:
In addition to the 3 vacuum hoses that attach to the airbox, I came across another, larger diameter hose that runs to the stock intake tube that runs between the MAF and the airbox. I haven't seen this hose in any pictures of intakes and I'm thinking it may be a MY98 DOHC kind of thing. (I have a MY98 RS)
I have another outlet on my Weapon*R pipe that is the correct diameter. This outlet was covered with a rubber cap when I got the intake, but I'm assuming it's there because it is needed in some applications and not others (i.e. the intake is for MY98-99 but only the MY98's need the larger outlet?)
Anyway, I just wanted to be a little more sure about it before I finished putting the intake on. I also have to buy a new large hose to replace the stock one because it kinks when I hook it to the large outlet on the intake, so I also have a bit of time before I purchase that and am ready to install again, so I figured I would try and get more info.
Thanks in advance,
Eric
AccidenT is offline   Reply With Quote
Old 12-17-2000, 08:35 AM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
My understanding is that your car wont idle without connecting this to the vacuum as well. I have not looked at the other post, but found this out when we did our prototype MY98 intake last month.
You could get a 1/2" t connector, and "T" it into the other vacuum line closest to it like we did, or get an extention to reach the spare outlet in the intake.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 12-17-2000, 11:54 AM   #3
MPREZYA
SCIC
Member#: 85
Post
Accident what you want to do it have the larger tube going to the large post at the middle of the intake and the other breather tubes will need to be T'd to the smaller post. I used the t pipe off my stock intake to make the connections after realizing I forgot to hook up a breather tube for the driver side.
Rich
MPREZYA is offline   Reply With Quote
Old 12-18-2000, 12:27 AM   #4
AccidenT
Member#: 2024
2005 Legacy 2.5i
Atlantic Blue Pearl
Post
Thanks for the responses!
I was all set to just hook up the stock large hose to the large outlet (I already have the T's to connect all the small ones to the small outlet) but the stock hose kinked pretty badly when I tried this, so I threw the stock intake back on until I could be sure.
Thanks again
Eric
COBB Tuning Surgeline Import Drag Series Round 2 June 6th, Woodburn Drag Strip! Cobb Tuning North West Impreza Club Forum -- NWIC 27 06-07-2010 10:10 PM
WRX vs. EVO Shootout - Round 2 - April 15, 2005 - Norwalk Raceway - don't miss it ! Dyno Flash Proven Power Bragging 252 04-25-2005 04:05 PM
Anyone going to round 2 of the WRX vs. EVO Shootout April 15 @ Norwalk Raceway (OH)? AcquaCow Mid Atlantic Impreza Club -- MAIC 5 03-07-2005 10:35 AM
South vs. East NMMHT Round 2 Spheris Off-Topic 18 03-04-2004 10:58 PM
GPSW vs. Anti GPSW Round 2 FunkerVogt Off-Topic 22 02-06-2003 06:12 PM
