Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 06-28-2004, 10:55 AM   #1
SjpWrx
Member#: 22554
2007 Corolla no PW!
WHITE miss my WRX :(
Default RPMs at idle acting funny..?
Ight i start my car up this morning at it jumps to 2k then settles at 1.2k then goes up to 1.8k then down again and it keeps repeating this. i only had it started for about 2 mins?
Thanks for any help you can provide.
Steve
Oh my mods are
Vinshu reflash
Turboback (catless)
Perrin uPpipe catless
IC hoses
HKS circle earth grounding kit.
SjpWrx is offline   Reply With Quote
Old 06-28-2004, 01:44 PM   #2
dubba you are ex
Member#: 59591
$100 Up/Downpipe
Installs PM me!!!!!!!!!!!
did you disconnect the recirc hose on your stock bov?
dubba you are ex is offline   Reply With Quote
Old 06-28-2004, 02:52 PM   #3
aerofan897
Member#: 61143
03 Cobb Stg II WRX
WR Blue
2 things you might want to try. One of the throttle cables usually comes way too tight from the factory. Mine was, so I loosened it up and it solved the problem.
http://forums.nasioc.com/forums/show...hreadid=555880
Second solution might be here, just a little cleaning required in the idle air control:
http://forums.nasioc.com/forums/show...hreadid=552528
aerofan897 is offline   Reply With Quote
Old 06-29-2004, 12:00 AM   #4
SjpWrx
Member#: 22554
2007 Corolla no PW!
Thanks for your help guys ill look into the idle air cntlr.
Old 06-29-2004, 01:06 AM   #5
subiesown
Member#: 53798
My car does the same thing. Only when I start it cold, never when it warm. I always thought that was the car trying to warm the engine to safer operating temps, so you could drive it sooner.
subiesown is offline   Reply With Quote
High RPMs at idle jayjay75 Service & Maintenance 6 05-30-2009 05:03 PM
rpms acting funny pho4life3100 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-11-2008 12:16 PM
Low RPM at idle dpk777 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-26-2007 12:43 PM
Bouncing RPM at Idle...? Chigae Normally Aspirated Powertrain 10 08-02-2006 10:28 AM
problem - fluctuating rpm at idle Jejunum Normally Aspirated Powertrain 12 03-30-2003 01:09 PM
