Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-28-2004, 01:10 PM   #1
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
Default Would this Fit?
Would a T-25 turbo off a second gen eclipse fit on a 02 2.5rs. I'm looking at setting up a homemade kit and have a T-25 laying around. Any way to make this work or is it not worth it?
Sharmin7 is offline   Reply With Quote
Old 06-28-2004, 01:16 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
depends on if u got a hookup for pipe making/the tools/the money
Old 06-29-2004, 11:50 AM   #3
Unsung Boxer
Member#: 37196
anything will fit if you make it. Technically, no turbo fits you car. Read FAQ's... its your first step twords turbocharging. You wont get far in this forum w/ generic questions like that.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-29-2004, 11:53 AM   #4
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
those things are pretty small. You could do it.
I would be very custom though.
Hitokiri is offline   Reply With Quote
Old 06-29-2004, 04:42 PM   #5
subieworx
Member#: 47769
Actually it would be less custom than you think. Buschur Racing makes a kit that will allow you to bolt on a Mitsu turbo. You can get an UP with the Mitsu flange and a 3" DP with the Mitsu flange. They sell a complete kit with the UP, DP, 16G turbo and and necessary install parts for $1500. Goto www.buschurracing.com to check it out.
As far as that rubo goes, it is small. With a new wastegate actuator from Forced Performance you will be able to make it hold 18psi till the red. However, it doesn't flow very much and running that much boost on a turbo that is at least 6 years old...
subieworx is offline   Reply With Quote
Old 06-29-2004, 06:24 PM   #6
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
Don't forget he's coming from a '02 2.5RS, not a wrx. Looks like the kit you're talking about is for a wrx. He might be able to use that if he uses the wrx exhaust manifold + crossmember. Then there's engine mgmt to worry about..etc...
And 18 psi is a lot of boost on the high compression ej25 Don't know if the small turbo can push 18 psi for a 2.5. Any compressor maps out there?
cRayZee is offline   Reply With Quote
Old 06-29-2004, 10:28 PM   #7
subieworx
Member#: 47769
I'm sure there are some out there. I would check dsmtalk.com.
An 02 would just need a wrx manifold and it should work fine. And with the CFM that little hair dryer puts out you could run probably 8-10 psi, not much boost. Probably would also need some injectors and fuel management as well. What size do the 2.5's come with?
Would this fit on a GC OK? moss Tire & Wheel 22 08-21-2004 01:03 AM
Would this fit my RS? SubarLu Tire & Wheel 5 02-23-2004 12:59 AM
Would this fit on my Impreza?? STi-Mulation Vancouver Impreza Club Forum -- VIC 7 06-28-2003 05:37 PM
Would this fit in my impreza? STi-Mulation STi Forum Archive 1 06-27-2003 09:47 PM
Would this fit? agent007kimball Car Audio, Video & Security 1 02-12-2002 02:12 AM
