Old 02-08-2001, 04:17 PM   #1
Andre Vandenberg
Member#: 501
1998 2.? RS Turbo ;)
RBP
Post Anyone's car stalling and then dies after hard corner
Hi guys & gals,
Just wondering, This weekend while trying out my new Yoko's in the local canyons, my car salled and died comming out of a hard left hand turn. Now before you all go: You need at least 3/4 tank of fuel..... I KNOW THAT.... My tank was full, and this is not the same type of stall. The car acted like power to the fuel pump was cut. Tach was working, no lights was on or flashing exhaust temp was 0, so I figure no fuel for SOME reason.
Just thought if someone else had this happen to them before, it sure would save me from pulling my car COMPLETELY apart.
Andre
Andre Vandenberg is offline   Reply With Quote
Old 02-08-2001, 04:30 PM   #2
Scoob_13
Member#: 123
2005 WRX STi
Blue and gold
Post
Check fuel pump power relays for a weak connection and also the fuel pump itself for a rattling. Any hints of leaking fuel or anything like that? Possible gas cutoff short?
Oh, and you need 3/4 tank of gas, thought I'd throw that out there for you.
Phil Howell
99 RS
Scoob_13 is offline   Reply With Quote
Old 02-08-2001, 06:07 PM   #3
Andre Vandenberg
Member#: 501
RBP
Post
Thanks Phil,
Looked at all those.... no prob found. But I will not be able to know for sure till I go "play" again.
Apparently there is some kind of "rollover" sensor that cuts fuel in case of roll over, that may have come loose or defective also. But I wil not be able to check that till next week.
Andre
Old 02-08-2001, 10:43 PM   #4
hacman
Member#: 3603
Post
I was readin in the SCC Project car about Fuel Sloshing. This is when the fuel in the tank moves to one side during a hard corner, and momentarily starves the fuel pump. Hence the stall. If you keep it above 1/2 tank, it shouldn't happen. Another alternative is setting up a secondary Fuel Cell, wired inline with the existing one.
I'll try to find the article/issue/page for you.
hacman is offline   Reply With Quote
Old 02-09-2001, 01:56 AM   #5
Jay_UK
Member#: 296
Post
I'm about to send over a anti-surge tank setup with secondary pump for someone to try.
We'll let you know how it goes
J.
Jay_UK is offline   Reply With Quote
Old 02-09-2001, 04:57 AM   #6
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
If it was on a hard LEFT turn, then it wasn't fuel starvation due to fuel slosh -- the pickup is located on the right side of the tank.
Steve
SteveS is offline   Reply With Quote
Old 02-09-2001, 05:00 AM   #7
hacman
Member#: 3603
Post
....and if I'd read the whole thing, I woulda seen the part about the full tank....
Welp, dunno what to tell ya. I haven't had the opportunity to run er hard yet.
Old 02-09-2001, 05:17 AM   #8
Adrian128
Member#: 3346
Post
hmmmmmm.. maybe there is a loose connection with the fuel pump, or maybe you need a new fuel filter.. hope you fix it soon
Adrian128 is offline   Reply With Quote
Old 02-09-2001, 05:29 AM   #9
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Question
Are you sure about that roll-over sensor? SCRAPPYDO rolled his car several times (over a cliff) and landed on his roof with the car running!
-Mike.
[This message has been edited by mpaone (edited February 09, 2001).]
mpaone is offline   Reply With Quote
Old 02-09-2001, 09:18 AM   #10
Andre Vandenberg
Member#: 501
RBP
Post
I am NOT sure about the rollover sensor, but I will check it out next week. Apparently it is located above the charcoal canister at the back of the car.
This is definately NOT a fuel slosh problem, although I would be interested in one of those pick up "thingies" of yours Jay. being able to run less than 1/2 a tank sure will save a LOT of weight at the autox.... If I will EVER see another one.... So Damn busy lately.
Andre
Old 02-09-2001, 09:27 AM   #11
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Post
Rolover sensors are far from sure-things. sometimes they work sometimes they don't. in fact sometimes they jsut fire a cut off the fuel if you get too low... that's the best idea i've heard yet... a hyperactive rollover sensor
Safir is offline   Reply With Quote
car starts then dies after 10 sec raceckr Service & Maintenance 4 04-23-2010 09:41 PM
02 WRX starts then dies after a backfire bmv68128 Service & Maintenance 0 04-20-2009 09:27 PM
car dies after hard pull? SpicyPeaNut UTEC 12 09-21-2007 12:00 PM
my car starts and then dies somtimes, what could cause this? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-11-2005 06:30 PM
Spongey brake pedal after hard cornering Scoobie Steve Brakes, Steering & Suspension 13 06-06-2001 11:39 PM
