#1 |
Member#: 1654
NWIC
Vehicle:1998 GC8 Unicorn MV Agusta Brutale S |
So, I got as far as the part where you remove the bolt that is on one of the intake runners to replace it with a vacuum hose nipple. The bolt is square and my 7 mm open-ended wrench fit ok, but I had to move up to 8 mm to get a closed-end on it. It stripped rather easy.
![]() I am sure that some kind of loc-tite was used during assembly since the new part has white stuff in the threads. This is an OEM kit that I bought and all the parts/instructions are Subaru. So, is there a trick to getting this bolt out? The metal seems real soft, maybe low-grade steel. It's a square shape and is somewhat longish .. maybe a cm or 1.5 cm. I could file it square again, but I don't have anything smaller than 7 mm. I want to avoid cutting off the head, drilling the bolt and reverse tapping it. is there another way?
#2 |
Member#: 25796
Vehicle:1993 Legacy Turbo Burgundy |
Yeah, those square-head plugs are annoying.
That white stuff is sealant for the pipe threads. It may also be an adhesive, I guess. Vise Grips (actual name-brand Vise Grips, not no-name locking pliers) worked for me... |
#3 |
Member#: 17252
Vehicle:'06 WX8 59E |
Do it on a hot engine using large Channel-lock or Vise-grip type pliers. The pinch should be strong enough for the square end to start squishing. Don't let the tool hit TPS when the plug breaks loose.
#4 |
Member#: 18006
We totally mangled one on my friend's OBS a couple years ago. Never did get it out. He eventually just put a splitter on a vacuum hose off the manifold and used that instead of the square plug.
#5 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Try a crescent wrench on it before you mangle it any more. Most decent tool stores will carry female square head sockets.
#6 |
Member#: 52875
Vehicle:1999 OBS Silverthorne (2-tone) |
The 7mm open end wrench worked fine for me this past winter when I did the same thing you are doing. You didn't need to use the closed end of a wrench on it but now I would just get some locking plyers on it, vise grips work great, lock them on there tight and turn it to loosen it. Should work fine. It may be helpfully to run the engine to get it warm, not hot as it is a pain to work in there then.
#7 |
Member#: 25796
If you are using closed-end wrenches or sockets, they should be either 4-point or 8-point. 12-point and 6-point wrenches/sockets aren't designed to fit over squares.
#8 |
Member#: 9243
NESIC
Vehicle:05 Nissan Titan 06 B9 (hers) |
If the white material on the threads is to act as a sealer it is likely teflon tape. That shouldn't bind the bolt in any way. If you use vise grips or a better wrench, try nudging or rocking your torquing pressure instead of just leaning into it. The nudging action seems to break bolts free better than just cranking on it.
#9 |
Member#: 17252
OK, so how did it turn out?
| Thread Tools | |
| Display Modes | |
| 95 Impreza Cruise Control Kit | lmdew | 1993 - 2001 Impreza Specific Parts | 0 | 07-26-2007 06:59 PM |
| 99 Impreza Cruise Control Kit | Zoul | Private 'Wanted' Classifieds | 0 | 07-26-2004 01:24 PM |
| '97 OBS Cruise Control Kit for an Auto | Those Meddling Kids | Private 'Wanted' Classifieds | 6 | 06-12-2004 09:17 PM |
| Installing Cruise Control on MT GC8 | minx | Transmission (AT/MT) & Driveline | 0 | 03-07-2002 04:57 PM |
| need a TS cruise control kit | zabutter | Newbies & FAQs | 7 | 09-28-2001 01:40 AM |
