Old 06-29-2004, 12:12 AM   #1
AntonioS
Member#: 23233
2000 2.5RS-T
white
Default Intercooler options??
I'm finishing my jdm ej20 swap and I know have to worry about the IC issue. What top mounts fit in the engine bay? I just found the wrx i/c is out of the list cause is to hard to make it fit.
AntonioS is offline   Reply With Quote
Old 06-29-2004, 01:16 AM   #2
kaos200
Member#: 2692
which ej20?
kaos200 is offline   Reply With Quote
Old 06-29-2004, 07:56 AM   #3
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
If you are doing a swap for an ej20 engine ( i assume you are using the ej20 intake manifold) you should be able to use any TMIC used in the regualr WRX.
This become a problem in the regular 2.5rs since the throttle sits several inches back in the engine bay.
Elliot is offline   Reply With Quote
Old 06-29-2004, 06:43 PM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
its its the older ej20g then you will have to make some modifications to the ic and pipes to get the usdm ic to fit. The older ej20g came with an air to water ic, but the early wrx ic is an air to air which will bolt right up.
More info would help
subiekid is offline   Reply With Quote
Old 06-29-2004, 07:40 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
The WRX intercooler will fit, it's just a bitch to put it in and take it out.
scoobyimprza is offline   Reply With Quote
Old 06-29-2004, 09:33 PM   #6
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
If you used the USDM cross member, none of the aftermarket TMIC's will fit, (hood won't close) because the engine will be about 3/4" higher than with the older cross memebers.
yamarocket630 is offline   Reply With Quote
Old 06-30-2004, 12:48 AM   #7
AntonioS
Member#: 23233
2000 2.5RS-T
white
its a 1996 jdm ej20 and yes I used the wrx crossmember. I'm thinking of doing my own front mount kit
Old 06-30-2004, 02:32 AM   #8
BoostdScubaru
Member#: 42188
i have a saab 9-3 front mount core with endtanks i'll sell you... i can send pics if you want... pm me if your interested
BoostdScubaru is offline   Reply With Quote
intercooling options j3t Pre-2002 Factory Turbo Powertrain 45 04-07-2009 10:24 AM
intercooler options WRX34 Subaru Conversions 0 10-27-2005 10:12 PM
Some different intercooler options... WallyKincaid Subaru Conversions 5 10-19-2005 05:46 PM
Intercooler options... pfhlipwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-14-2004 12:39 PM
intercooler options? Red RS Normally Aspirated with bolt-on Forced Induction Powertrain 14 10-25-2001 11:05 AM
