Old 06-29-2004, 12:42 PM   #1
G.Subramaniam
Member#: 64528
Default Advantages of increasing wheel size ?
What is the advantage / disadvantage of going from 15 inch stock wheels to 16 inch alloy 12 lb wheels
G.Subramaniam is offline   Reply With Quote
Old 06-29-2004, 02:06 PM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
what car are you talking about that has 15 in. wheels? 12lb sounds light so i could only imagen good things would happen.
RS_to_WRX_swap is offline   Reply With Quote
Old 06-29-2004, 05:32 PM   #3
G.Subramaniam
Member#: 64528
I have a 1995 Legacy and a 1997 Impreza, they both come with 15 inch wheels
Tire rack has 15 inch wheels from SSR and 16 inch wheels from BBS and SSR that wiegh about 12 lb
So what is the performance advantage / disadvantage of moving from 15 inch to 16 inch wheels
Old 06-29-2004, 05:42 PM   #4
poison
Member#: 37678
No disadvantage on the street, except for the tires will be more expensive!
Advantages that I felt in the real world? Quicker turn in (extreme difference), quicker steering, less bounce from the tires, less lean in corners, more grip! Pretty much an improvement in everything a tire should do. Better looks too.
My WRX wheels are 16 lbs too, not 12 .
poison is offline   Reply With Quote
Old 06-29-2004, 08:51 PM   #5
G.Subramaniam
Member#: 64528
Thanks
Could someone tell me the advantage / disadvantage
wrt traction / performance in going from 195x60 to 205x 60 or 215x55
Old 06-30-2004, 12:16 AM   #6
pio!pio!
Member#: 4190
2008 Impreza WRX STi
poison: the benefit you are feeling is not necessarily of going to a larger rim, but becuase you went w/ a larger rim, you had a smaller/stiffer sidewall tire
if you kept the 15 but went with a smaller sidewall you would feel the same improvements
pio!pio! is offline   Reply With Quote
Old 06-30-2004, 09:24 AM   #7
Tire Rack Moderator
Member#: 1215
ext. 4362
quicker steering response
better handling
more lateral grip
better look
Old 06-30-2004, 12:52 PM   #8
Boxologist
Member#: 21118
Hi Gopal(if u are who i think u are)! the biggest improvement is getting different tires. bigger wheels is 75% cosmetic. u will get a bit more NVH(search to learn more) on a +1 or +2, but having higher performance tires the difference is immense. being abel to switch back to winter tires on the smaller wheels is a huge benefit too in NY.
Boxologist is offline   Reply With Quote
Old 06-30-2004, 02:10 PM   #9
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Bigger contact patch = more grip and less gas efficiency.
Shorter sidewall = less sidewall flex, stiffer road feel. Old cars used to use high sidewall tires as a "secondary" suspension. They really soften the ride. Modern suspensions are much better, and afford a car owner the luxury of low profile tires.
Stanley is offline   Reply With Quote
Old 06-30-2004, 04:05 PM   #10
poison
Member#: 37678
Of course
But 15's with low profiles would throw off the odometer, and look, um funny on this car. The idea is to keep stock diameter, unless there are special needs for the track, weather, etc.
Old 07-01-2004, 01:06 PM   #11
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
12 pound wheels will help acceleration, braking, turn in, overall grip (on all but a perfectly smooth surface), and last and least important- they look better. You might also notice a gain in fuel mileage, due to the less rotating mass you are accelerating. But if you are like most of us you'll just accelerate faster and not gain any mpg.
speedyHAM is offline   Reply With Quote
Old 07-01-2004, 01:46 PM   #12
YinUCSD
Member#: 44945
06 LGT wag
better handling
more lateral grip
better look
and better cornering stability too correct?
YinUCSD is offline   Reply With Quote
Wheel size performance advantage vintagemilano Motorsports 10 03-27-2006 04:49 PM
What is the advantage of a different sized master cylinder bore? snowman4us Brakes, Steering & Suspension 5 09-15-2004 12:35 AM
advantage of wider rear wheels and sizes? iloveturbos Brakes, Steering & Suspension 19 09-06-2002 04:45 AM
('93-'01) What are performance advantages of all wheel drive? Gage Impreza Forum 76 10-31-2001 06:45 PM
benifits of increasing intake plenum size WRXwannbe Normally Aspirated Powertrain 6 06-27-2001 09:33 PM
