Old 02-07-2001, 11:39 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post is it possible to de-stroke the 2.5?
Has anyone used the 2.0L Crankshaft in the 2.5RS to bring the Displacment down but raise the rpm's? I have always liked the idea of de-stroked engines (ex. a destroked Chevy 400ci small bloke with a 350 crank for 377ci for you American muscle nuts )
Is this possible? Thanks!
Eric
Eric SS is online now   Reply With Quote
Old 02-08-2001, 06:20 AM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Sure it's possible. If the WRX actually does have a forged crank, it would make an interesting project to use it in a 99mm bore 2.5L block. One of Trey Cobb's closed deck blocks, of course.
You would obviously need new rods and pistons, but a 99-100mm bore by 75mm stroke would be interesting. 9k rpm anyone?
(edited some numbers-- EJ25 is 99mm bore stock, 100mm overbore pistons are common.)
[This message has been edited by ColinL (edited February 08, 2001).]
ColinL is offline   Reply With Quote
Is it possible to look up the IPs used by an AIM SN? vision.dynamix Off-Topic 15 12-09-2008 02:37 PM
Is it possible to disengage from the world? blaster88 Political Playground 37 09-19-2005 08:56 PM
Is it possible to pop off the rings around the vents? spooledwrx Interior & Exterior Modification 11 06-24-2005 04:26 AM
Is it possible to just get the HKS Ti/CF Muffler? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-16-2003 10:30 PM
Is it possible to determine Phase 1/2 block from VIN? 2.5GT Normally Aspirated Powertrain 1 11-16-2001 05:22 PM
