Old 06-29-2004, 06:11 PM   #1
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
Default Leak stop
I have a slow leak in one rear tire (20psi in 5-7 days). This is the set that came on the car and I will be replceing them before the snow hits so I am just trying to get this one through the summer. Also it looks like the former owner took a chunk out of the side wall on the tire that is leaking. Dont know if this is the leak but I am sure the tire shop will tell me I need to replace it and will not fix the leak.
You guys know of anything I can put in the tire to stop the leak. I have heard that fix-a-flat is bad stuff. I know slime works well in a bike but I fear I would have to tip the guy $50 to clean the wheel when I get new tires. And will the weight be all messed up having added weight to one tire?
Sorry so long, thanks for the help!
bhall is offline   Reply With Quote
Old 06-29-2004, 06:24 PM   #2
Karl
Member#: 13110
Driving on a tire with severe sidewall damage is asking for trouble.
What are the tires on a 2002 Legacy GT? Probably RE-92 again?
My advice is to get a cheap used one from someone local to get you through summer.
Karl is offline   Reply With Quote
Old 06-29-2004, 06:34 PM   #3
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
Ok let me rephrase. The chuck is smaller than a dime and more of a "flap" than a chunk (ie I can pull the little flap up to reveal the chunk).
Tires are 205/55/16 yoko's (yk420). I dont really like the idea of running on 1 new tire and 3 @ 75% wear. Any problems with this with the exception of the friends ROTF
Old 06-30-2004, 08:16 AM   #4
Karl
Member#: 13110
If this is only to tie you over for summer, I would still go to a tire place to get a cheap used tire.
The tire is leaking somewhere. Have you asked the tire place to take the tire off and reseat it on the rim bead? I had a slow leak on a Nokian tire right at the crimp-on weight. The tire place took the weight off and used stick-on weight instead and that fixed it.
Old 06-30-2004, 09:19 AM   #5
Tire Rack Moderator
Member#: 1215
ext. 4362
take it to a shop and find out where it is leaking ....
Old 06-30-2004, 11:07 AM   #6
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
Thanks for the replies guys! I will take it in to the shop today. If they tell me I need a new tire due to the sidewall issue I guess there is a reason for that. If that is the case I will get all 4 new, any sug. from you guys on a good all year tire. I snowboard in the winter so good in the snow whould be nice as well as sticky in the summer. Is that a pipedream?
Thanks again!
Old 06-30-2004, 12:37 PM   #7
Tire Rack Moderator
Member#: 1215
ext. 4362
Thanks again!
yes but, look into the Sport 5000's or tyhe P-Zero Nero M&S
Has anyone ever used radiator stop leak? WRXedUSA Off-Topic 8 04-02-2005 03:35 PM
Help me stop a bad leak? dexterous Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-19-2003 09:52 PM
oil leak stopping fluid lotusTT New England Impreza Club Forum -- NESIC 2 09-01-2003 07:59 PM
how to stop a serious oil leak? philo2g Tri-State Area Forum 3 08-28-2002 11:50 PM
how to stop a leak? soulcrusher500 Normally Aspirated Powertrain 0 03-26-2002 09:03 PM
