Old 02-14-2001, 11:01 PM   #1
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Question steering wheel is rattling on hard right turns
When I take hard right turns my steering wheel rattles like it is loose inside. It does not seem to do it on left turns. I think I might have heard of this happening after an accident but I have never hit anything to knock it out of alignment. Anyone else have this or know why it does it?
Scootr
scootr is offline   Reply With Quote
Old 02-15-2001, 05:09 AM   #2
wrxwannabe
Member#: 1178
2004 WRX STI
02 Legacy GT Wagon
Post
Wouldn't happen to be your keys hitting the steering column would it? Took me a while to notice that
Later
Eric
wrxwannabe is offline   Reply With Quote
Old 02-15-2001, 07:45 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Exclamation
i would check:
the weights on the wheels - did you loose one?
dirt in the wheels - is the wheeel out of balance?
and if all else fails.. get an alignment.
j.
www.subiegal.com
Old 02-15-2001, 08:52 AM   #4
grimlock
Member#: 2683
2011 STi 5-Door
Post
If you're understeering, it might be a little bit of wheel hop. That'll make the steering wheel rattle a little bit.
Ross N.
grimlock is offline   Reply With Quote
Old 02-15-2001, 09:11 AM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Breaking the front inside tire loose while cornering hard--power understeer--feels that way too.
ColinL is offline   Reply With Quote
Old 02-15-2001, 10:10 AM   #6
AWDriver
Member#: 1230
Post
I think this is normal, both of the RS's I've driven have a rattle which sounds like its coming from somewhere in the steering column, but only when taking a very tight corner and going over a bump at the same time. Subaru mechanic said it was normal, too. If it happens under other circumstances, I'd get it checked out. BTW, this really bothered me for a while (a brand new car shouldn't rattle!), but now it's just part of the car's character, along with a couple of dozen other rattles, squeaks, clicks, clunks and burbles that my car makes. Imprezas are not quiet cars!
AWDriver is offline   Reply With Quote
Old 02-15-2001, 04:20 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
do you have an aftermarket alarm? The ***** heads who put mine in, didnt even bolt the alarm module to anything they just tucked it behind the knee bolster, everynow and then it bounces around.
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
Old 02-15-2001, 07:33 PM   #8
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Post
WOW!!! Another person!! I've been dealing with this headache on my '00 GT since I the day I bought it. NEW CARS SHOULDN'T RATTLE LIKE WRECKED ONES!!!!!!!!!!!! I've learned to deal with it. I've had the dealership do everything possible to fix it--they don't know what it is. SUX!
Old 02-16-2001, 12:48 AM   #9
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
from what I've seen there are like 3-5 joints for the steering wheel to connect to the main column. What I theorise is that the wheels start to slip and vibrate up and down. Then the column (since it's connected directly in the wheels) will absorb the vibration and send it up the "stupidly designed" steering column up to your hands.
If you want it to stop, get a better suspension, that will make the tires stick to the road until they can't.
WRXwannbe is offline   Reply With Quote
Old 02-16-2001, 12:28 PM   #10
Rez
Member#: 1958
1999 Impreza 2.5 RS
Rally Blue Pearl
Post
I've had my car for almost 2 years now and I have no rattles. What can I do to fix this?
-Rez
<IMG SRC="http://www.reverberations.com/Storage/Images/scrambles.gif" border=0>
Rez is offline   Reply With Quote
Old 02-17-2001, 01:02 AM   #11
grimlock
Member#: 2683
2011 STi 5-Door
Post
Find the nearest washboarded dirt or gravel road and drive up and down it for about two hours. That'll fix you right up.
Ross N.
Clicking on hard right turn mars636 Transmission (AT/MT) & Driveline 2 07-13-2008 04:11 PM
Shuts off on Hard Right Turns. Help Tirpitz56 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-28-2007 07:27 PM
Just replaced axles...now vibration on hard right hand turns Erexxx Transmission (AT/MT) & Driveline 0 08-13-2007 04:06 AM
noise on hard right turn Leadfoot77 Brakes, Steering & Suspension 5 05-08-2007 11:04 AM
Fuel cut off on hard right turns? tep Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 05-03-2004 06:23 PM
