Old 06-29-2004, 06:43 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default uppipe flex section
has anyone else had them leak on them?
my welder buddy connected one to my uppipe and its leakin out of both ends looks like i have to go in there and weld it but it looks impossible to weld from the inside
anyone have any clues?!
thanks
alex
Old 06-30-2004, 12:49 AM   #2
Unsung Boxer
Member#: 37196
yeah, i had a problem w/ one leaking the other day. if you had a stethascope, you could listen to confirm if its leaking inside the braided part, or at the weld itself.
It always seems to me that 1/10 of those damn flex joints leak. Over time u will see black carbon build up where it is leaking. If its real quite, dont worry about it.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-30-2004, 02:29 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i have a stethascope but it leaks so much under 0 pressure im sure itd POUR under exhaust pressure <i tested it w/ water>
Helix Uppipe with flex section TTUsuby Engine/Power/Exhaust 12 01-28-2007 05:31 PM
Helix-like uppipe with flex section em199si Private 'For Sale' Classifieds 9 09-29-2005 12:02 PM
FS! 2002 WRX TurboXS uppipe w/ flex section soulo5000 Private 'For Sale' Classifieds 0 08-07-2005 10:13 AM
Does anyone has leaky flex uppipe right at the flex section?? dcwrx2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-15-2005 12:41 AM
Vishnu uppipe with flex section... WRX_02_227 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-11-2003 03:14 AM
