Old 02-15-2001, 05:22 AM   #1
Marquis
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
Post Drain Plug Thread Size
Does anybody have any idea what thread size the drain plug is? I'd just go measure the darn thing but then, you see, all my oil comes out..
I ask because Aeroquip has this fancy drain plug system that looks to make changing oil much cleaner (plus it looks all trick and stuff...).
Marquis is offline   Reply With Quote
Old 02-15-2001, 02:43 PM   #2
Rez
Member#: 1958
1999 Impreza 2.5 RS
Rally Blue Pearl
Post
Try here:
http://www.fumotovalve.com/
Works great.
-Rez
<IMG SRC="http://www.reverberations.com/Storage/Images/scrambles.gif" border=0>
Rez is offline   Reply With Quote
Old 02-16-2001, 04:43 AM   #3
Marquis
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
Post
That looks kinda cool, but you should check out the Aeroquip FLOCS system. It's a two-part system that is much less messy than that one. It's got a female part that you push a hose onto a barbed end and then push the female end into the coupling that threads into the drain plug hole. It's quick and very clean.
No link because the only good info they have is in their .pdf file, but check out www.aeroquip.com
Old 02-16-2001, 11:25 AM   #4
Rez
Member#: 1958
1999 Impreza 2.5 RS
Rally Blue Pearl
Post
Much less messy? I hook up a simple hose to the nipple, put the other end into a gallon jug and flip the lever. No drip, no mess. Can't get much easier than that.
-Rez
[This message has been edited by Rez (edited February 16, 2001).]
03 wrx oil drain plug thread size edogg6565 Service & Maintenance 1 04-16-2010 11:34 AM
Oil drain plug thread size? shemoves Service & Maintenance 3 10-07-2005 01:14 PM
oil drain plug thread size? vile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-22-2003 10:59 AM
Oil Drain Plug Thread Size daytontp General Community 10 01-04-2002 11:35 AM
Drain plug thread size??? LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-13-2001 01:30 AM
