Old 06-29-2004, 08:07 PM   #1
rs702
Member#: 64251
Unhappy failed smog test
Just bought a 00 impreza rs went to get it smogged they said it failed cause of a fuel trim malfunction which causes my CEL to be on. If i take off my battery terminals and get my CEL light off temporary will it pass the smog test?? Can anyone let me know, muchly appreciated
rs702 is offline   Reply With Quote
Old 06-29-2004, 08:15 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What state are you in? Does your emission test incorporate an OBDII scan? If it does, a reset is not your answer because this will set the OBDII readiness test status to "not ready" and cause you to fail. You would need to drive the car for enough time to complete the readiness tests again, by which time the CEL might return.
You would be far better off finding out what the actual code is and taking the necessary steps to track down and correct the underlying cause, rather than just trying to mask it to pass an inspection. Chances are that whatever it is is causing your car to not run as well as it should, as well as using more fuel.
Fail Smog Test after OBDII Reset truckresi Normally Aspirated Powertrain 9 07-30-2006 03:47 AM
Would the aftermarket FMIC fail the smog test in california. ix8vii Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-06-2005 03:17 PM
failed smog test rs702 Normally Aspirated Powertrain 4 06-29-2004 10:36 PM
Failed smog test... illmatic Off-Topic 23 04-12-2004 02:40 PM
Failed CA Smog Test - NOx too high AVATAR-X Service & Maintenance 5 01-31-2003 02:46 AM
