Old 06-29-2004, 08:09 PM   #1
rs702
Member#: 64251
Unhappy failed smog test
Just bought a 00 impreza rs went to get it smogged they said it failed cause of a fuel trim malfunction which causes my CEL to be on. If i take off my battery terminals and get my CEL light off temporary will it pass the smog test?? Can anyone let me know, muchly appreciated
rs702 is offline   Reply With Quote
Old 06-29-2004, 08:47 PM   #2
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Where are you? And you can get the cell pulled at autozone.
joubtt is offline   Reply With Quote
Old 06-29-2004, 10:18 PM   #3
Section 8
Member#: 821
No, it will not pass the plug in test. They will see that the computer has not gone through enough driving cycles to have accuratly detected any problems.
However, I tried passing the smog check that way, and the guy working didn't really know what was going on. Since the station didn't have an AWD dyno to run the car on, they mearly checked it with an idle test.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 06-29-2004, 10:29 PM   #4
Vacca Rabite
Member#: 55491
WRX, 1968 Jeep m715,
1976 VW Porsche 914
Where do you live?
In some places (MD for example) if you inplug the battery the DMV will reject you and you have to come back for a retest.
If it happens again, they usually just pass you the second time instead of dealing with the problem.
Zach
Vacca Rabite is offline   Reply With Quote
Old 06-29-2004, 10:36 PM   #5
Section 8
Member#: 821
Wisconsin.
9 times out of 10 it probably wouldn't happen the way it did. THe other guy wanted to send me to a different station with AWD stalls, the first guy said they should idle test it. Second guy agreed.
Fail Smog Test after OBDII Reset truckresi Normally Aspirated Powertrain 9 07-30-2006 03:47 AM
Would the aftermarket FMIC fail the smog test in california. ix8vii Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-06-2005 03:17 PM
failed smog test rs702 Service & Maintenance 1 06-29-2004 08:15 PM
Failed smog test... illmatic Off-Topic 23 04-12-2004 02:40 PM
Failed CA Smog Test - NOx too high AVATAR-X Service & Maintenance 5 01-31-2003 02:46 AM
