Old 02-06-2001, 11:11 PM   #1
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
Post CE light on please help
ok i installed my N1 exhaust today and it was great. But my damn CE light came on any idea why? I reseted my ecu and when i started it the light just lit up again. Then after idleing for 15 min the car jus stalled. Also i cleaned my K&N air filter for my cold air intake. I think i might of oiled it too much and some oil got into the air box. Could that be the problem? Ir when i was installing the muffler could i have knocked an o2 sensor or soething? Please help that light is very annoying and bright. Thanx
ac_gohan is offline   Reply With Quote
Old 02-07-2001, 01:09 PM   #2
Tangmere
Member#: 572
Post
CE could be anything, from a loose gas cap, to well, just about anything. Unless you changed or fiddled with the cats (your O2 sensors are by the cats) I doubt your exhaust would have anything to do with it. Then it might be a "cats below threshold" code, which is a minor problem. Go have the code pulled, most places charge you $30 bucks, it removes all the guessing and they reset it for you (assuming you can fix what the code reads).
Tangmere is offline   Reply With Quote
Old 02-07-2001, 01:12 PM   #3
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Dont go to a dealer, they charged me $85 to have my code pulled, it ended up I was right, bad 02 sensor wiring.
STiShawn is offline   Reply With Quote
Old 02-07-2001, 06:11 PM   #4
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
Post
ok so once you find out what the problem is by the code, then you can reset the ecu? Because i did reset the ecu and the light didnt go away. Also when i decelerate and go to idel my tach teeders from 800 rpm to 600rpm and it makes a everytime the tach bounces up the car shakes a little. What could it be its driving me crazy! So you cent get rid of the CE light until you get the code? Ok say i found out the code then what? im really confused and need a lot of help.
Old 02-07-2001, 06:28 PM   #5
Quart2000
Member#: 4064
2000 2.5rs
Blue Ridge Pearl (sold)
Post
I had the same problem. It was the O2 sensor. I took it to the dealer and wasn't charged anything because it is under warranty.
I noticed problems, i.e slight hesitation a light idle roughness. the ironic thing is my CE light came on after I installed my Tannabe Racing medallion allthough the problem started before that.
My service rep said there was a problem with some of the O2 sensor put on some cars and they had replaced quite a few on 2000 and 2001 model subarus.
Quart2000 is offline   Reply With Quote
Abs Light on – Please help identify broken part (pic inside) turbomania Brakes, Steering & Suspension 2 08-07-2007 11:10 PM
CE Light PO461 please look/help AndyM Normally Aspirated Powertrain 5 02-26-2003 02:10 AM
another CE light question, please dont flame me hondaconvert Normally Aspirated Powertrain 6 05-09-2001 07:55 AM
CE light problem please help me! ac_gohan Bay Area Impreza Club Forum -- BAIC 15 02-10-2001 10:56 PM
No speedo, CE light and stalling - Help? BoomerRS New England Impreza Club Forum -- NESIC 20 12-06-2000 08:55 AM
