Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 06-29-2004, 11:29 PM   #1
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Exclamation Shifting FAQ: Read if you are new to AWD or a MT
This post is meant to be an informative narrative catered toward:
a. New manual transmission owners
b. People with specific shifting problems
c. People inexperienced with the differences between an AWD car vs. a FWD or RWD car
d. People wanting more information on transmissions in general
Where can I find good background information of transmissions? A good general reference for new people as well as a refresher for more advanced users is How Stuff Works' Transmission Tutorial.
Where can I find good background information on differentials? A good general reference for new people as well as a refresher for more advanced users is How Stuff Works' Differential Tutorial. More Subaru specific information is contained on this thread.
Is shifting different with an AWD car vs. a FWD or RWD car? One has to visualize the power transfer in a car to get a better understanding. In a FWD or RWD car, if you shift or launch the car too aggressively, the excess power is transmitted to the tire(s), which will spin. Put another way, excess power is "burned off" through tire smoke. In an AWD car, if you shift or launch the car too aggressively, the excess usually isn't enough to overpower the tires' grip. In this situation, the excess power must be absorbed somewhere else in the drive train. Though some drive train shock is normal, in an overload situation, excess power is transmitted to the various driveline components, which can accelerate wear and tear.
Where are the shifting differences most apparent? Starting off in first gear and the 1-2 shift are the most common causes of driveline shock. Obviously, there is reason to shift responsibly in every gear but these are the most commonly seen problematic shifting issues.
What is the best way to learn proper shifting for the first time? This post by NASIOC member DrDRum contains some outstanding advice for the first time or novice manual transmission user.
Is resting my hand on the shifter bad? From the WRX Owners Manual: "Do not drive with your hand resting on the shift lever. This may cause wear on the transmission components". This advice should apply to every Subaru MT model. That being said, the safest course of action is to keep both hands on the wheel unless actually shifting.
What about starting off on hills? For advanced users, this is no problem. For first time or novice users, this can be a frightening and stressful experience. Until you can successfully master the art of a hill start, this is what you do:
1. Pull up the handbrake.
2. Attempt to take off as normal.
3. When you feel the car working against the brake, slowly release the brake.
Using this technique you will have a rollback free and safe start on a hill situation.
When I shift from 1st to 2nd, there is a thump sound coming from the rear end of the car. What causes this? The thump is the rear differential hitting either the cross member or the bottom of your car. This is caused by driveline shock due to aggressive driving and shifting. This type of driveline shock is a direct result of maximum acceleration. A thump from the rear end can occur with any shift, but most commonly occurs during the 1-2 shift due to it having the greatest internal transmission speed differential between first and second gear.
How to I remove the thump sound? Many people have experienced a reduction in rear differential noise by the installation of stiffer STi transmission mounts and/or differential mounts. The wisdom of this method is highly debated though. Common sense thought processes indicate that the stiffer mounts only transfer the shock to internal transmission and differential components. The ultimate cure is to modify the shifting technique where the driveline shock occurs.
How do I shift without the thump? You should wait until the point where you are no longer pressed into the back of your seat to let the clutch out on your second gear shift. As to the actual application of this technique:
1. You are in first gear, taking it to your favorite shift RPM.
2. Once you reach this RPM, let off the gas pedal and depress the clutch.
3. Shift into second. (Items 2 & 3 can be done quickly)
4. "The wait". Judge it based on your body's movement. Visualize your pelvis as the axis....when the rearward pressure of acceleration leaves your body and you feel as if you can naturally lean forward at the waist.....this is the shift point.
5. Release the clutch.
This is a shifting technique that requires some practice due to variances from car to car. Yes, it's slower, but better for your rear differential and transmission in the long run.
How do I launch properly? Launching is a technique for people wishing to drag race their cars. A good launch will give you a low 60ft time and goes a long way to wards showing off the prowess of AWD and a lower overall time slip. There are many launch techniques and you must decide on what method is best for your goals. For instance, a first time drag racer might want to use the most conservative launch to get used to the feeling and an advanced user with an upgraded transmission may side step the clutch at 6000 RPM. This article and this article both provide launching advice. Additional advice may be obtained by experienced locals, searching the forums, or by good old fashioned practice at your local drag strip.
Many feel that a good way to get a feel for the proper launch while being extremely kind to your transmission is to practice on a loose surface such as dirt or on a wet surface. Though the acceleration isn't the same, it familiarizes you with the sound, timing, and technique.
Why is it hard to go into first gear or downshift into first? The fault mainly falls on an old transmission design. This article details the design flaws and associated problems with the first gear on 2002-2006 Subaru Imprezas with the 5MT. These transmission issues have since been addressed by using dual cone synchros on the 2004+ STi, 2005+ Legacy/Outback, and the 2006+ WRX.
Many users often see a dramatic reduction in first gear or other transmission issues simply by changing their synthetic transmission fluid back to regular or by using a recommended synthetic. Many Subaru owners tend to change fluids more often than needed and use synthetics. Many synthetic gear oils designed for manual transmissions can create or enhance transmission/shifting issues in Subaru transmissions. This article provides a wealth of information on transmission gear oils.
What is the easiest way to downshift into first? Many users report great success in downshifting into first gear by using the double clutch method.
Why is it hard to go into reverse? Reverse is a straight cut gear with no synchros. This means reverse can be tricky from time to time. Problems can be grinding or inability to go into reverse. Since reverse is usually engaged as soon as the vehicle has started, the lack of fluid temperature and flow plays as role as well. Most reverse problems can be overcome by selecting a forward gear first, rolling forward slightly, double clutching, or some other technique. What works for one car may not work for another, so experiment with the technique that works best for your car. "Problems" with reverse engagement are actually common with many transmissions from many manufacturers.
What is heel/toe? Heel/toe is a shifting technique. It refers to using the toe of your foot to apply the brake, while using the heel to apply the gas. It will result in the driver's right foot (when looking down at it) to appear to be pointing left as opposed to straight up and down. Many also substitute this technique by using the left and right portions of their foot to the same effect. Though not heel/toe (more like big toe/little toe) in appearance, it serves the same function. It is usually used for rev matching during a downshift, but has other uses as well
How do I heel/toe? This depends on the user and pedal arrangement. Some users prefer to shift their right foot and use the traditional toe on brake/heel on gas technique. Others use their big toe for the brake and little toe for the gas. The use depends on the width of the drivers' foot and if the vehicle is equipped with adjustable pedals or not. Some prefer one method or can use both equally as well. Once the placement is decided upon, it can take awhile to become proficient. Practice on the street, use on the track is wise advice for those considering this technique.
When should I heel/toe? Heel/toe driving is generally reserved for road racing and those who do lots of rev matching. The average user will probably not see any benefit from using this or other advanced techniques.
What is rev matching? Matching the engine speed to the transmission input speed before re-engaging the clutch. Rev matching is both a term and a technique.
How do I rev match? Rev matching can either occur through the use of a double clutch technique, as discussed below, or through blipping the throttle while the clutch is depressed. Blipping the throttle is a term that indicates the driver revs the engine based on need while the car is in neutral or the clutch is in. Rev matching can be performed via the heel/toe technique as demonstrated in the animated picture above.
When should I rev match? Rev matching is generally reserved for downshifting. Proper rev matching ensures that a vehicle's suspension will not be upset by reapplication of power when exiting a corner. This is really an advanced shifting technique and is not required for the average or above average driver in most cases. There are those of the opinion that rev matching will save wear and tear on the clutch though.
What is double clutching? Technique for rev-matching the transmission's intermediate shaft to the output gear that is to be selected.
How do I double clutch?
1. Power is removed and clutch is disengaged (clutch pedal down).
2. Transmission is shifted from original gear to neutral.
3. Clutch is re-engaged (clutch pedal up). (Driver now has control of intermediate shaft speed by controlling engine speed).
4. Driver blips the throttle to match intermediate shaft speed to speed of new gear. (This takes practice to get the right match).
5. Clutch is disengaged (pedal down).
6. Transmission is shifted from neutral into new gear.
7. Clutch is re-engaged (pedal up) and power is applied.
Steps 1- 3 can be done casually or quickly. Steps 4 - 6 must be done quickly so that the intermediate shaft doesn't slow down again before it's engaged. If step 7 is also done quickly, the engine will also be 'rev-matched' to the rest of the driveline so that engagement will be smoother.
(The steps on this animated graphic do not coincide with steps described above)
When should I double clutch? The only instance one may need to double clutch would be during the 2-1 downshift on a 02-04 WRX. Many find this a useful technique for a smooth 2-1 downshift due to the WRX's transmission design flaw, or in any gear where there appears to be problems with the synchro. The 2004+ STi and the 2005 Legacy/Outback have different first gear synchro system and do not experience the same problems when performing the 2-1 downshift. Otherwise, this is really an advanced shifting technique and is not required for the average or above average driver in most cases. There are those of the opinion that double clutching will save wear and tear on the transmission synchros though.
What is flat shifting? In a nutshell, flatshifting is where your right foot never leaves the gas pedal. You quickly engage the clutch at the shift point, shift gears, and side step the clutch. While terrible on an OEM gearbox, this can safely and effectively be performed on some aftermarket gearboxes for improved racing times. Some dogbox transmissions also take well to another method. This method requires a slight lifting of the gas to unload the dogs, a lightning fast shift, then back fully on the gas. Though you technically can perform either of these two shifting actions in an OEM synchro equipped gearbox, it falls along the same lines as parachute packing. Yes, you can do it yourself, but it's best left to professionals.
Old 06-30-2004, 12:33 AM   #2
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Do Subarus have transmission problems? When the WRX was first released many people unaccustomed to AWD vehicles became owners. Since it was a quick car, naturally many of these owners spent some time at the drag strip. Transmission problems obviously occurred. The cause of these transmission problems can be mainly attributed to many drivers' inexperience with AWD vehicles.
Have these problems changed? Transmission problems appear to have turned the corner. Mid 2002 saw an important physical change in the Subaru transmission in the form of a dump valve with does not allow the end user to perform a true clutch dump launch. While this doesn't protect against sustained abuse, it will protect the ignorant from occasional folly. Also, word started spreading that acceleration and shifting techniques should be modified to transfer the power properly. Buying a new clutch is far cheaper than a new transmission.
As well, sometime (no one knows for sure when) in mid 2003, the WRX transmission saw an upgrade in gear width. This width increase was up to RA width or approximately 1 mm wider than the previous models. After careful research here you will find that most broken transmission stories are coming from 2002 owners with inexperience and the narrower gears. This isn't to say that wider gearset owners are excused from breakage, but the odds are more in your favor vs. the older MY owners.
Other shifting articles:
spdusa.com's shifting article
Shifting Technique by Brian Brown
Double clutching article
Heel/toe article
Heel/toe article
Cobb Tuning's Gear Oil article
GravelRash's shifting article
Editors Note
This post was created because I wasn't able to find a good shifting/driving/transmission FAQ. I came up with the text based on LOTS of searching here. Upon reading this you should have an idea of to properly drive your vehicle to maximize performance and it's lifespan.
If you find an error in this FAQ, please PM me with factual details and I will update this post.
Last edited by Unabomber; 06-07-2006 at 04:57 PM. Reason: Sorry buddy....I need more space!
Bishop is offline   Reply With Quote
Old 06-30-2004, 01:40 AM   #3
Angulimala
Member#: 43814
2004 WRX Wagon
Silver, SPT exhaust
outstanding! fantastic diagrams.
Thank you.
Angulimala is offline   Reply With Quote
Old 06-30-2004, 03:32 AM   #4
sdogg3kgt
Member#: 38397
2002 Lovemachine
Very Nice. Thanks for some of the info.
sdogg3kgt is offline   Reply With Quote
Old 06-30-2004, 03:38 AM   #5
Sublime5260
Member#: 30488
2006 Acura TL
Gray
wow! amazing!!
Sublime5260 is offline   Reply With Quote
Old 06-30-2004, 04:44 AM   #6
collegedropout
Member#: 42569
adds to the douchery
level round' here...
Another great Unabomber FAQ
collegedropout is offline   Reply With Quote
Old 06-30-2004, 10:27 AM   #7
glepko
Member#: 19651
This is my personal favorite bomber FAQ. This should be on the underside of every new WRX sunvisor. It should also be required reading before any new forum account is activated.
glepko is offline   Reply With Quote
Old 06-30-2004, 11:40 AM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Another nice one. .....especially in light of the recent onslaught of "shifting" threads. This should help.
One note in regards to the below Q&A:
Originally posted by Unabomber
Is resting my hand on the shifter bad? While there isn't any specific information that this causes or accelerates transmission related failures on Subarus, it is a concern for some other manufacturers' vehicles. That being said, the safest course of action would be to keep both hands on the wheel unless actually shifting.
There actually is some information in the Subaru manual that addresses this concern. This is from Section 7 of the 2003 WRX Manual: "Do not drive with your hand resting on the shift lever. This may cause wear on the transmission components". Your response kinda sounded as though Subaru had nothing to say on the subject.
Anyhow, it's nice of you to take the time to write these FAQ's up. Thanks again.
- Kean
Kean is offline   Reply With Quote
Old 06-30-2004, 11:49 AM   #9
Slowpoke
Member#: 19879
2004 WRX
Java Black
Great job as always Unabomber. This should be required reading.
One small point: Under "When should I rev match" you say, "There are those of the opinion that rev matching will save wear and tear on the transmission synchros though." I think this statement is more applicable to double-clutching. Rev matching doesn't do anything for synchros, as you are still using them to spin up the intermediate shaft.
A more accurate statement for rev matching would be "There are those of the opinion that rev matching will save wear and tear on the clutch".
Slowpoke is offline   Reply With Quote
Old 06-30-2004, 01:31 PM   #10
mr_yellow
Member#: 39983
2003 WRX Wagon
Thanks unabomber!
mr_yellow is offline   Reply With Quote
Old 06-30-2004, 02:46 PM   #11
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Heh, rev matching/double clutching/heel toe shifting... Sure they're not absolutely necessary for normal driving, but it sure makes normal driving a heck of alot of fun.
I sorta skimmed but i think you should also note that heel-toe downshifting is the same as double clutching, except that you're using the brake at the same time.
[nice writeup] [should also be posted/stickied in the transmission/driveline forum too]
Old 06-30-2004, 03:54 PM   #12
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
Incredible thread! As a newbie, I always am eager to learn more. I got myself into a bit of a disagreement the other day, and needed some straightening out. Thanks a lot!
doster82 is offline   Reply With Quote
Old 06-30-2004, 05:25 PM   #13
purplegrape
Member#: 6678
Oh My wheel is
about to come off!!!
Another great read!!!
Keep up the good work... this is going to be saved in my favorites
purplegrape is offline   Reply With Quote
Old 06-30-2004, 06:09 PM   #14
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
Awesome write-up as always.
Sticky! Sticky! Sticky!
SupaSizeFries is offline   Reply With Quote
Old 06-30-2004, 07:11 PM   #15
Nicklbrso
Member#: 44887
00 GC6
Unabomber is the man!
Nicklbrso is offline   Reply With Quote
Old 06-30-2004, 08:18 PM   #16
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
My thanks to Kean and Slowpoke for their additions. I didn't know there was a blurb in the owners manual about hand resting. I did know about the other errors, but sometimes when you work on something so long, the errors kinda blend together.
My thanks to Psydotek for your input. It is valid, but I felt I couldn't put into words all the combination shifting techniques. I listed all the major advanced ones individually, but felt the combo possibilities were just too much.
And finally my thanks for the wonderful comments. I hope to continue down my mental FAQ list. Readers can also thank Mike Wevrick as he was the genesis behind this idea. Oddly enough as I was working on this FAQ, there was a TON of shifting/driving questions this week, so my post came at a good time as well.
Old 06-30-2004, 08:20 PM   #17
Psydotek
Member#: 44168
2003 Yellow WRX
...Oddly enough as I was working on this FAQ, there was a TON of shifting/driving questions this week, so my post came at a good time as well.
It's true, i've already put my thoughts onto like 3 or 4 separate threads recently about shifting.
Old 06-30-2004, 08:31 PM   #18
Kean
Member#: 25187
'08 Foz Prem TGM
....now that the FAQ is up, looks like you'll be wasting more time in SCIC then?
Old 06-30-2004, 08:34 PM   #19
Psydotek
Member#: 44168
2003 Yellow WRX
You might have a point there.
[SCIC is my OT]
Old 06-30-2004, 09:02 PM   #20
sonicblue
Member#: 25227
2012 Escape
Incorrect. In case people are still confusing terms, let me try:
"Rev-matching" is the general concept of matching your clutch speed to the crank speed as the clutch is released after a gear change. It doesn't tell you anything about HOW it's actually accomplished. More terms are needed.......
"Double-clutch" specifies exactly how you rev-match. It is in contrast to the often omitted, but just as descriptive, term "single clutch."
"Heel-toe" is the term for when you apply the brake while simultaneously depressing the throttle in order to match revs during your downshift. It is wholly separate from "double" versus "single" clutch.
That is, you can "double clutch rev match" or "single clutch rev match." Additionally, if you're braking while downshifting, you can either "heel-toe double-clutch rev-match" or "heel-toe single-clutch rev-match."
While ridiculously impressive to say that you "routinely heel-toe double-clutch rev-match," it's also the truly correct term (if that is, in fact, what you do).
sonicblue is offline   Reply With Quote
Old 06-30-2004, 09:15 PM   #21
VSG
Member#: 19435
Rev-matching is a part of the Double-Clutch process. So "heel & toe, double-clutch" is good enough.
VSG is offline   Reply With Quote
Old 06-30-2004, 09:51 PM   #22
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Well in theory you could double-clutch without rev-matching, and you can definitely rev-match without double-clutching.
Thanks but all I did was suggest it. You did all the work and its great as always!
Mike Wevrick is offline   Reply With Quote
Old 06-30-2004, 11:08 PM   #23
fastsubie
Member#: 21999
2012 Wrx
he is the FAQ master ya know..
Fess
fastsubie is offline   Reply With Quote
Old 07-01-2004, 07:26 AM   #24
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
These transmission issues have since been addressed on the 2004+ STi and 2005 Subaru 5MT.
Are you certain about this one - I have also read that the 05 transmission was to have dual cone synchro's, but there was a post on here not too long ago where someone asked that same question of Subaru and was told the transmission was unchanged.
Mid 2003 saw an important physical change in the Subaru transmission in the form of a dump valve with does not allow the end user to perform a true clutch dump launch
This actually was implemented somewhere around mid-2002 - the dump valve is there from then on. (I have an 02 manufactured in 5/02 and I have the dump valve on the clutch slave cylinder on my car)
Old 07-01-2004, 08:46 AM   #25
Chuck H
Member#: 20442
Excellent post. The only thing I'd like to see changed is the removal of "There are those who are of the opinion" about clutch wear in the rev-matching section and synchro wear in the double-clutching section.
To me, that's kind of like saying "There are those who of the opinion that the earth is round". Rev matching absolutely saves wear on the clutch. It's not an opinion, it's an easily demonstratable fact. Same with synchro wear using double-clutching.
The only question is whether saving the wear is worth the effort. Most people don't care if the clutch lasts 150,000 miles of normal use, but would last 200,000 if they rev-matched every downshift. Same for the synchros.
Chuck H is offline   Reply With Quote
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-02-2015 11:25 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 373 04-27-2015 09:41 AM
Car Buying FAQ: read if you are buying/selling/leasing a Subaru or other car Unabomber Newbies & FAQs 72 12-01-2014 12:05 PM
Subaru FAQ: Read if you are a new Subaru owner! Unabomber Newbies & FAQs 41 10-11-2013 03:04 AM
