Old 11-01-2008, 10:58 PM   #101
jetski247
Member#: 188171
04 sti baby
wrb
the subi is nothing to float compared to the high torque tug boat cummins engine we have in the company truck. i can up shift all gears and down shift all gears w/no grinding or forcing at all. the car can float really well compared to most others, i guess they have good syncro's or somthing.
when i do it, i let off the gas and put light pressure on the stick and it slips right out, before your foot is completely off of the gas you can just slip it right into the next gear as the rpm's fall, and when its in, just slowly increse the rpm again and your on your way. the sti is real easy. just didnt know if anyone else does this, that double clutch thing sound way too complicated, seems way easier to float than to double clutch..........but thats just me.
jetski247 is offline   Reply With Quote
Old 11-01-2008, 11:54 PM   #102
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
It's come up before, most people either believe that by rev matching to float gears that it doesn't wear on the tranny very much, or the exact opposite, that you'll blow the tranny up in a short amount of time. Meh, it's your car.
I learned floating gears driving tractor trailers, as well. If you don't rev match, up and downshifting, it won't go in gear, no matter what you do with the clutch. In the car, the synchros will make it possible to shift without rev matching, a much easier to deal with situation.
I can float all through the gears, up and down in my STI, just like I could in the last stick shift I owned, an '85 Plymouth Horizon. You can float gears in most any car, if you rev match and go easy on it.
Having said that, I don't try it when I'm cranking along spinning the engine at high RPMs. There's a lot of torque that can be applied to the tranny, breaking syncros, and wearing gears out (they call it grinding for a reason, no?) Generally speaking, I treat my car like a car, and not a truck with a tranny capable of handling 1000 lb/ft of torque and just use the clutch almost all the time when I shift gears.
Just because you can do something, doesn't mean it's a good idea to. Like I said, it's your car, do what you want with it. I doubt floating between 4-6 when cruising around is going to damage anything too quickly, and it is rather fun to do.
reddoak is offline   Reply With Quote
Old 11-02-2008, 09:24 AM   #103
jetski247
Member#: 188171
04 sti baby
wrb
yes, i never float gears when driving aggressive. i use the clutch most of the time but it is kinda nice to just shift. i usually float going into 3-6, 2 can be done pretty easy but its much lower of a gear and takes more finesse. its somthing i do every now and then when theres not much traffic and im just cruisin around, showin off the ride.
oh yeah, ive also herd that the final gear should use a clutch from some 18 wheeler floaters just because of the load i guess but they have way more weight.
Old 11-02-2008, 10:16 AM   #104
JGreene
Member#: 173624
2010 WRX STI SE
Whenever I shift from 1-2 aggressively, it never sounds smooth and clunks like crazy. I barely ever run through first gear at WOT due to this. Is there any tips for a nice 1-2 aggressive shift? This is my first manual tranny car, so Im not sure how its supposed to feel.
WRX 5-spd for trans.
JGreene is offline   Reply With Quote
Old 11-02-2008, 02:38 PM   #105
jetski247
Member#: 188171
04 sti baby
wrb
i never get a clunk but i have an sti, 1-2 is a good solid squish of the suspension
Old 11-02-2008, 10:49 PM   #106
tryfe
Member#: 169008
2005 WRX
transmission?
tryfe is offline   Reply With Quote
Old 11-02-2008, 11:27 PM   #107
Shohin
Member#: 170188
2016 STI Limited
It's your rear diff . . . . TiC makes some stiffer bushings (the Klunk Killer I think).
Shohin is offline   Reply With Quote
Old 02-06-2009, 03:36 AM   #108
phillyrex
Member#: 194381
2008 wrx
no other articles ive read go into the details needed to make decisions on informed shifting practices
phillyrex is offline   Reply With Quote
Old 04-07-2009, 11:30 PM   #109
AeroWRX
Member#: 199026
2004 WRX Wagon
Originally Posted by REX8 View Post
just normal wear...
...just as down-shifting without the heel and toe causes normal wear on a clutch...yet most still heel-toe.
Without heel-toe (braking) and just using rev matching doesn't that have the same clutch wear as heel-toe?
AeroWRX is offline   Reply With Quote
Old 04-13-2009, 02:45 PM   #110
jssmoots
Member#: 206626
World Ralley Blue
Not sure where I should be asking this and am not allowed to post a new thread as I am a newbee...
I just replaced my clutch (among other things - cv boot, anti-sway bars, spark plugs) and now my shift lever moves when I step on/let off the accelerator. This is especially apperant when in 3rd gear.
I've gone through the shift linkage and everything seems like it's in the only way it'll fit. Did I forget/break something?
jssmoots is offline   Reply With Quote
Old 04-13-2009, 04:18 PM   #111
polaris
Member#: 66663
2011 VW GTI
maybe '15 STI?
Mine did that too for a long time but it has lessened over time. I asked back then too and was told its normal and not a concern.
polaris is offline   Reply With Quote
Old 04-14-2009, 02:15 PM   #112
jssmoots
Member#: 206626
World Ralley Blue
Ok, that's what I was hoping for. Thanks for the response.
Old 05-24-2009, 02:34 PM   #113
bcounty
Member#: 208081
2004 Impreza WRX
Java Black Pearl
Thanks
bcounty is offline   Reply With Quote
Old 06-06-2009, 11:43 PM   #114
CGilman89
Member#: 212708
2002 wrx wagon
Sedona Red Pearl
awesome post, really explains alot to a newbie like me. cant wait to try the double clutch for the 2-1 since i own an 02
CGilman89 is offline   Reply With Quote
Old 08-19-2009, 06:04 PM   #115
BoostN420
Member#: 201178
03' Rex
Psm
Loving all he wrte ups I'm reading from the Unabomber
real f'n informative
BoostN420 is offline   Reply With Quote
Old 08-19-2009, 11:56 PM   #116
bluemicamatt
Member#: 220246
2007 WRX TR
keep reading them! took me about a week, and i feel like i'm quite familiar with my ride now. I woulda wasted a lot of time searching NASIOC threads, and possibly hurting my car, if it weren't for his contributions.
bluemicamatt is offline   Reply With Quote
Old 12-11-2009, 06:08 PM   #117
mrwiggles_04
Member#: 214855
2005 WRX Wagon
WR Blue
Great job. Very in depth
mrwiggles_04 is offline   Reply With Quote
Old 12-12-2009, 01:03 PM   #118
b1kanobi
Member#: 217349
2007 2.0 Impreza RS
aspen white
nice write up. very informative especially for new awd owners such as myself
b1kanobi is offline   Reply With Quote
Old 04-07-2010, 03:44 PM   #119
IWantASuby
Member#: 190420
'13 BRZ Limited
'04 Impreza Outback Sport
I second that, lots of good information to help with the overall driving experience of these cars. I was hoping that, being an '03, my car would have the upgraded gears, but the date on the door jam is 6/02..so I'm not sure =/ the transmission shifts fine, occasionally takes a little while before it wants to go into first during acceleration, but other than that no problems.
IWantASuby is offline   Reply With Quote
Old 04-12-2010, 01:26 PM   #120
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
01 S2K, 91 Impulse RS
3 years after reading this thread I can finally double-clutch heel toe. (together that is!) Took a year just to make doubling natural and instinctive, and over another year upon that to double clutch while braking.
It is such a relief to be able to pick any gear at any time. I can't even really do it if I stop to think about it or its too slow to really be effective.
This is just a note to others, the techniques described in this thread are not easy to train you brain/feet into. Give it time and you will be rewarded. I've passed on these techniques to many who think its just a waste of time or too difficult.
Example: Oh snap, a 90 degree turn is coming up that you didn't notice, 55 speed limit to 55 limit! You're in 6th, so stand on the brake pedal, double into 2nd with your heel and giggle on boost/Vtec! Now try that same type of shift in snow going downhill in a straight line.
I am so easily amused. I won't go to the drag strip but I'll go up and down that snowy hill practicing over and over.
Another funny thing is, the Subaru pedal layout is way easier to heel toe (in my opinion, foot size) than Honda. Strange indeed.
AaronCompNetSys is offline   Reply With Quote
Old 05-23-2010, 02:19 AM   #121
jonnylin1
Member#: 232228
2008 SWP WRX -BYE <3
WHITE FTW - AW e92 335i
wow! these are amazing information! would've helped so much if i had found this before i started learning about driving MT lol but it still helps now just to read it over! thanks!!
jonnylin1 is offline   Reply With Quote
Old 05-31-2010, 09:11 PM   #122
DarthArma
Member#: 248098
2002 impreza wrx
midnight pearl black
Thank you sir. This is great
DarthArma is offline   Reply With Quote
Old 06-01-2010, 11:38 PM   #123
bluesmobile440
Member#: 247485
2006 WRX TR
Just wanted to say thanks to the almighty subie master. The WRX is so much different than any other car I've ever driven. You've been the man.
bluesmobile440 is offline   Reply With Quote
Old 06-22-2010, 03:28 PM   #124
DarthArma
Member#: 248098
2002 impreza wrx
Unhappy tranny
My tranny went two weeks after getting my 2002 wrx. The mechanic said 2nd gear "exploded which could only be cause by abuse (so eff your warranty the previous owner gave you with the car)" I think it was on its way out due to how hard the previous owner drove it.
But a habbit i noticed i do alot (when driving in general) is how I gas it alot when i shift into 2nd and let go of the clutch. Is that bad for the tranny? what Rpm should i be in when i'm going into 2nd?
Any assistance to this awd new comer would be very much appreciated. Getting my transmission back in about a week and i dont want this to happen again
Old 06-23-2010, 12:40 AM   #125
bluesmobile440
Member#: 247485
2006 WRX TR
Your RPMs are going to depend on wheel speed. If you're going 20 mph, I find blipping the revs to 2k gets me fairly close to where I need to be. Basically for 2nd gear, 1k RPM = 10 mph. Just as an FYI, you'll kill your clutch eventually if its half way engaged and you're gassing it alot. Just try and blip the throttle to where it needs to be let the clutch out fairly fast (1-2 seconds).
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Car Buying FAQ: read if you are buying/selling/leasing a Subaru or other car Unabomber Newbies & FAQs 82 10-19-2015 06:42 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-02-2015 11:25 PM
Subaru FAQ: Read if you are a new Subaru owner! Unabomber Newbies & FAQs 41 10-11-2013 03:04 AM
