Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 10-12-2011, 11:14 AM   #151
ezil71
Member#: 207118
2003 Wrx Wagon
I'm in China right now, and nobody here knows jack about how to shift!
everyone, and I mean everyone, lugs the engine BIG time
taxi's, bus drivers and all of the people I've driven with - they up shift at like 1000k!
Like, getting all the way to 4th, when I would still probably be in 1st!
Lots of new cars here too, less than 5 years old, if not newer for many of them, and a ton of VW's (all the taxi's are Jettas or some variation of the old Jetta body)
In any case - worth mentioning in this thread that the goal is to keep rpms in a range for around town type driving - 2500-3500 or so - and up/down shift as needed to stay in that range
(it is painful to see all these drivers killing their new cars!)
/end rant
ezil71 is offline   Reply With Quote
Old 12-29-2011, 10:14 PM   #152
Neff 11 2.5i
Member#: 277410
11' 2.5i Wagon
Mmmm juicy info, love it!!
Neff 11 2.5i is offline   Reply With Quote
Old 12-31-2011, 05:19 PM   #153
tricktraxxas3
Member#: 288312
2007 WRX STi
Is it bad to sit at a light holding the clutch in comparison to putting the car in neutral? (didn't see it in the thread)
tricktraxxas3 is offline   Reply With Quote
Old 12-31-2011, 05:59 PM   #154
Bald_Wrex
Member#: 236005
2000 Impreza 2.5RS
Not necessarily but it will wear out the pressure plate fingers quicker I would imagine.
Bald_Wrex is offline   Reply With Quote
Old 01-01-2012, 04:47 AM   #155
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
S2K, Impulse RS, NC Miata
Not the fingers, but the bearing the fingers ride on. It wears any time the motor is spinning and the clutch is depressed.
Holding the clutch in isn't really a concern as you will typically get a new throwout bearing with a clutch replacement, clutches wear out first. A related point is this if you do let out the clutch and sit in neutral at a light: letting out the clutch in neutral spins up the transmission so when you press in the clutch to engage first gear, your syncros and forks are wearing to slow the trans back to a stop before it engages. When depressing the clutch from neutral going to first, give it a second to spin down before pushing it into first.
Apply same principal to double clutch, double rev match if putting it into first while moving, remembering that the trans is spinning at idle motor revs when depressing the clutch. Example: 15mph coasting in neutral, after depressing clutch the trans at idle is already at the right speed for 2nd so you can quickly slot it into 2nd. If you desire 1st gear, idle speed is not high enough so you should rev the motor in neutral to 1st gear revs, depress clutch, quickly slot 1st gear, rev match again to 1st gear speeds, release clutch.
AaronCompNetSys is offline   Reply With Quote
Old 01-01-2012, 06:29 AM   #156
tricktraxxas3
Member#: 288312
2007 WRX STi
Thanks for the help. I'm learning stick on my wrx and want to make sure I don't create any bad habits.
Old 01-01-2012, 12:26 PM   #157
w0ng3r
Member#: 305528
2011 WRX
Wish I had read this when I bought my car back in April, would've saved me some embarrassment on the way back from the dealership
w0ng3r is offline   Reply With Quote
Old 01-07-2012, 10:04 PM   #158
MINIz guy
Member#: 305218
Good thread. I've been driving a manual transmission for 1 week now and have taught myself how to get smooth starts and rev match/double clutch for smooth downshifts. It isn't perfect but I'm going to need more than 1 week and 200 miles to do the movements without thinking.
I want to learn heel-toe but have a question.
Can heel-toe really be used in a street application? Every time I try, I end up stomping on the brakes just to roll my foot over to blip the throttle. I usually end up going slow enough that I can just straight put it into the lower gear. Is there a technique that I'm doing wrong?
I want to learn how to heel-toe so I don't have to downshift as early for a turn. My usual method is double clutch/rev match 4th -> 3rd before the turn and then once I'm straightened out, I rev match 3rd -> 2nd to get some acceleration out of the turn. I'd like to get the 3rd -> 2nd shift before the apex of the turn so I can get out faster.
MINIz guy is offline   Reply With Quote
Old 01-07-2012, 11:11 PM   #159
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Heel toe is racing only, to use it otherwise is to be practicing or doing it to impress someone. In a street car with synchros, there's no reason to do it unless you talk to those people who wear tin foil hats and come up with some psycho babble.
Old 01-08-2012, 03:16 AM   #160
Scooby207
Member#: 255687
11 WRX DGM
Heel- toe takes a lot of practice so keep at it if you really want to learn. Also, I use the inside and outside part of the ball of my foot NOT my heel at all.
@tricktaxxas3
I was told to keep it in gear... That way if you are rear ended or something like that the car stalls and is in gear and doesn't roll through the red light into the intersection and possibly get t-boned
Scooby207 is offline   Reply With Quote
Old 01-08-2012, 05:56 PM   #161
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
I do all the fancy stuff because I enjoy it, it helps when I'm out attacking a back road, and it's a generally smooth ride overall. My goal is to be as smooth as an auto box, and the rare "I didn't even notice you were shifting" is the highest complement.
You really have to let these techniques get burned in, it took me a long time before I could do as you describe smoothly. I wear thin shoes and position my foot so I can swivel it easily. The soft pedal in a Subaru will make it easier for you to learn, hard pedals aren't as noob friendly. Keep at it and you will have a fun skill that no one else has.
Part of you saying you end up going slow mph is just because you are being careful and not aggressive. To get a heel toe or double heel toe you have to be aggressive before it feels right. Rarely you can be aggressive on the street while being safe so it just takes patience.
Old 01-09-2012, 01:43 AM   #162
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
The reason of most concern for us spirited drivers with staying in gear is related to the for-aft balance of the car. This trick comes in much more handy than in just emergencies, but also keeps you safer when you are having fun.
Keeping the car in a gear where it is in a higher rev band offers you access to an instant amount of deceleration through the engine friction. This can be controlled linearly with the throttle, allowing you to shift the weight of the car forwards and backwards with very precise control. You can load up the fronts or the back axle depending on how you need to balance grip, with the goal of never driving at ten tenths of your tires grip. Keeping them balanced at around a maximum of 8/10ths, you have room for the the unexpected and emergency situations. Many drivers drive at 10/10ths of their front tires grip and 5/10ths rear, making some understearing bad driver habits. A car driven in experienced hands balanced with front axle at 8/10ths and rear at 8/10ths will always be faster, safer, and more fun than one where the driver is oblivious and just cranks the steering wheel til the tires squeal.
Old 01-09-2012, 01:49 AM   #163
Scooby207
Member#: 255687
11 WRX DGM
^ makes sense to me
I thought he was asking about when at a complete stop at a light in which case I'm not sure how all that applies....
Did I miss something?
Old 01-09-2012, 01:54 AM   #164
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
You didn't miss anything, I know my raving isn't related to stop lights. The idea of doing all this fancy shifting stuff is so you can eventually do them at places other than stop lights, like through a fast series of bends on your favorite country road. I wouldn't dare try a 9k downshift before a fun sweeping corner until I had practiced it a bazillion times at stop lights going slowly.
Old 01-09-2012, 02:27 AM   #165
Scooby207
Member#: 255687
11 WRX DGM
Ok...cool
well, thanks for the info
Old 01-13-2012, 07:50 PM   #166
MINIz guy
Member#: 305218
I'm getting heel-toe down now. I tried with wide Clark's Desert Boots first and now can do it with boat shoes which are much narrower. My method is to roll my foot over and bring the heel to the gas pedal too and I can blip it eventually. Just takes a while to get comfortable.
I just need more seat time with my new Impreza! I know how to do all downshifting methods but need more time memorize all the motions.
Also, I've grinded my gears a few times now. Have I caused any serious damage by grinding a few times?
Old 01-13-2012, 08:29 PM   #167
Scooby207
Member#: 255687
11 WRX DGM
I doubt anything serious but with that said any grinding is bad
Old 02-15-2012, 03:36 PM   #168
Dailoh
Member#: 310149
2012 WRX base Sedan
Unless I read through all the replies too quickly, I dont see this question being asked. I apologize in advance if someone else already said this. Anyway:
I have always Heel Toe downshifted. In my old 3000GT, the pedals were far enough part and far enough from the side wall that I can use my Heel and Toe.
In my Honda Fit, the pedals are close, but the throttle height is much closer to the brake that I can do Big Toe Pinky Toe.
In my new WRX, the gas pedal is so low compared to the brake pedal and so close to the right side wall that I definitely cannot do Heel Toe and having a lot of trouble doing Big Toe Pinky Toe without over-reving.
Is there anything I can do to raise the gas pedal? How are you guys coping with this or am I just a horrible driver?
Dailoh is offline   Reply With Quote
Old 02-15-2012, 06:55 PM   #169
Scooby207
Member#: 255687
11 WRX DGM
The right shoes can help I hear although I think that's really personal preference. It's all about practice... It's never easy to get the hang of it in a new car. I thought it was tricky when I got my first subie and now it's second nature.
I dont know about moving the pedal... I would just keep at it. That's my advice.
Old 02-15-2012, 08:20 PM   #170
Bpatts
Member#: 288358
2005 Wrx Sedan
Here is a question I have yet to find,
During a normal daily drive, when coming off a stop, what is the ideal rpm the car should be at when you release the clutch that isn't considered launching or lugging?
I try to do it between 1250-1750 rpms, I have a friend who brings it up to 2500 on his subaru every time.
What's the general consensus?
Bpatts is offline   Reply With Quote
Old 02-16-2012, 01:06 AM   #171
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
I shoot for 1500 because it feels right to me
furiouswrx is offline   Reply With Quote
Old 02-16-2012, 12:46 PM   #172
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
In my opinion, it depends on the health of your clutch and weight of your flywheel. My WRX has a healthy clutch and heavy flywheel, so I take off gently by using the inertia method. I rev it to about 2k, let off the gas almost completely, and then let out the clutch fairly quickly. The initial grab on the clutch pulls the revs down fast but the car is moving by the time the revs get to low, and I can get back on the gas before it dies. It dips down below 1k sometimes with this method.
My Honda has a weak clutch (its dieing) and a super light flywheel. Reving it up to 2k and dumping it doesn't work at all, so I have to hold the revs at 2-2.5k as I ease out the clutch.
To the best of my knowledge, as long as you don't hold the revs over 2.5k with the clutch partially depressed, you are not burning your clutch up. Don't be afraid to adjust your style.
You are not horrible, don't be afraid to think the car is flawed to your feet Your brake pedal should be fully adjustable, take it to a mechanic to have it adjusted if you have never done it to make sure you don't damage your master cylinder like I almost did.
I had to adjust my brake pedal over an inch. You may need to firm up your pedal too with mods, if your style requires a firm pedal (my style favors a soft pedal). TiC brake brace, upgraded braided lines, upgraded pads and fluid are ideas.
Old 02-16-2012, 01:40 PM   #173
cheezmunky
Member#: 167627
2011 WRX Ltd Hatch
I also rev my car up to around 2k, let off the gas about halfway, and then let off the clutch. It usually fully catches around 1200 rpms.
As far as heel-toe goes, I agree that during light braking the brake pedal sits too high to perform heel-toe shifts successfully, but the whole practice is only needed on modern cars when racing. In that case you'd be under heavy braking and the pedals should line up pretty well. That's just my .02; take it as you will
cheezmunky is offline   Reply With Quote
Old 05-24-2012, 02:33 AM   #174
lefor3
Member#: 320309
2004 WRX
Hmmm, quick question, I've been driving a manual (a FWD RSX-S though if that makes a difference) for about 3 years now and am looking to get a Bugeye.
Is it necessary, or more correct to do this method shown in this thread at a complete stop in first?
1) Clutch depressed, 1st gear, Rev up to 2000RPM
2) Slowly let off clutch while maintaining the 2000RPM
this whole time, I was taught (and seen other people) this method to start in first gear:
1) Clutch depressed, in 1st gear, slowly let off to where you can kind of feel the car lurk forward
2) Give it some gas and you'll be around 1500RPM with foot off the clutch
Is there a better, right, wrong, etc. way to this? Sorry if it's such a noob question, just rather learn now then damaging a clutch/transmission. Thanks!
lefor3 is offline   Reply With Quote
Old 06-05-2012, 01:36 AM   #175
easterbran
Member#: 307359
'05 STi Stage II
I find (in my 05 sti) that I can move the car very little by just letting off the clutch. I generally give it a bit of gas as I begin to let the car lurch forward. However, in an 08 Elise, I have to give it gas immediately otherwise I'll stall. I think it just varies car to car, transmission to transmission.
easterbran is offline   Reply With Quote
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 386 09-10-2016 07:42 PM
Car Buying FAQ: read if you are buying/selling/leasing a Subaru or other car Unabomber Newbies & FAQs 83 09-10-2016 04:48 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 116 08-01-2016 11:03 PM
Subaru FAQ: Read if you are a new Subaru owner! Unabomber Newbies & FAQs 41 10-11-2013 04:04 AM
