Old 06-30-2004, 12:17 AM   #1
Calsoldier
Member#: 56538
2004 WRX
Default Remove burnt plastic from exhaust?
Hey guys,
My bosal catback has some burnt bumper material on the tips (you can't see it under the bumper much, but you see if it you come up really close).
I would like to take that stuff off. Any ideas on how to remove the burnt-on stuff from the tips?
Oleg
Calsoldier is offline   Reply With Quote
Old 06-30-2004, 12:30 AM   #2
BrianH
Bing user
Member#: 44383
I got a really really fine grit sand paper and just went over it lightly. I had a ton though.
BrianH is offline   Reply With Quote
Old 06-30-2004, 01:01 AM   #3
Calsoldier
Member#: 56538
2004 WRX
I was thinking about that, but I'm afraid I will ruin the polished look of the tips.
The one way I thought of doing this is probably heating up the tips and wiping the stuff off, but I'm not sure if there's an easier way to do it.
Oleg
Old 06-30-2004, 01:09 AM   #4
subiesown
Member#: 53798
Yeah I was gonna suggest taking off the back section, and use a heat gun on it, wipe it, then use some type of chemical to remove the remaining thin layer of plastic.
subiesown is offline   Reply With Quote
Old 06-30-2004, 02:20 AM   #5
eightballrj
Member#: 18520
2005 L GT Limited
sand it with sandpaper and then get two different rubbing compounds... one that is more abrasive and one that polishes.
Richard
eightballrj is offline   Reply With Quote
smoke pouring from engine+burnt plastic smell? imprezaowner27 Service & Maintenance 19 10-19-2009 12:02 PM
Burnt Smoking smell from exhaust ?? kokob Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 03-20-2006 02:24 PM
removing plastic from front bumper Hot XXX Pics Interior & Exterior Modification 2 06-09-2005 04:16 PM
I smelt burnt plastic sha_zapple Off-Topic 9 11-27-2004 10:55 PM
Removing black plastic piece from '02 front lower grill? j y Interior & Exterior Modification 6 11-30-2001 09:48 PM
