Old 02-15-2001, 10:11 PM   #1
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Question Fuel Pressure problems
I installed one of Shiv's hi-flow fuel pumps tonight. I also have a Vortech SFMU (which is basically a RRFPR).
After installing the fuel pump in the tank with the car in the "on" position I can adjust the idle fuel pressure to about 40 psi, which is about 2 psi higher than normal. So that is fairly close.
When the car is running I am unable to get the fuel pressure lower than 54 psi at idle. I have adjusted the vaccum set screw from all the way closed to all the way open and fuel pressure changes by less than 1 psi. Before adding the new pump I was able to have it at 38 psi (stock). It seems the vaccum adjustment isn't doing anything.
With this much pressure at idle I am hitting 85psi when on boost. Which is WAY too high.
Has anyone encountered anything similar? Has anyone else installed Shiv's pump without a Tec-II? The instructions that came with the Vortech unit are a joke and don't indicate much of anything, other than use the vaccum adjust to obtain the correct fuel pressure when the car is at idle.
All pressures are being indicated by my Autometer Electric fuel pressure guage.
Any input would be appreciated.
Thanks,
Aaron
AaronB is offline   Reply With Quote
Old 02-16-2001, 12:20 AM   #2
IMPBOY
Member#: 65
Post
Huh? normal idle pressure is 38 psi? How come mine reads 32 psi? Under full throttle, it's like 42-44 psi. Is something wrong here?
00 rs
IMPBOY is offline   Reply With Quote
Old 02-16-2001, 01:45 AM   #3
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
Ok I got it figured out here is the thread from the Vishnu board where Shiv explained it to me in the newbie terms I needed
http://www.vishnuperformance.com/ubb...ML/000499.html
Thanks Shiv.
Impboy,
Mine always read 37-39 at idle before the turbo was added, not sure why your RS is reading so much differently?
Aaron http://www.azscooby.com
Fuel pressure problem, need some advice. canjee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-21-2009 08:34 PM
high fuel pressure problem, blew a hole in fuel line blowbyu24 Built Motor Discussion 12 07-17-2008 09:09 PM
Fuel Pressure Problem - Need Help dwarren Water/Methanol Injection, Nitrous & Intercooler Cooling 4 07-02-2007 07:42 AM
HELP!!! Fuel Pressure Problem!!!!!!!! burton1181 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 02-13-2005 04:24 AM
Fuel pressure problems LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 17 11-22-2001 02:18 PM
