Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 06-30-2004, 10:55 AM   #1
subedude17
Member#: 65332
93 L seiries wagon
white
Default running gear
am thinking about buying a ea82 turbo wagon, but i currently have a ea82 carby and i know that the gear box clutch and 4wd running gear fistly isnt constand 4wd and is rather fragile and i wondered if anyone knows how long the standard gear would last and how much it would cost me to change the running gear for either wrx or legacy running gear???
subedude17 is offline   Reply With Quote
Old 06-30-2004, 11:01 AM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
First, unless you are already experiencing some problems, the EA82T trans and such isn't fragile.. it can take quite a beating.
Second, are you asking about putting in a WRX motor/trans/diff combo, or just the trans because you want AWD? If you are talking about the just the trans, there are Fulltime 4WD gearboxes available for the EA82. That would be a much easier swap than going through the trouble of making an adapter plate and all that. I have the fulltime 4wd in my 87 EA82 TurboWagon.. so they are out there.
and finally, if you are after a complete drivetrain swap with the EJ20G, AWD trans and matching rear diff, check out www.ausubaru.com . A number of those boys have done the swap and will probably be able to brek it down for you.. Plus they are in your neck of the woods.
Calebz is offline   Reply With Quote
Old 06-30-2004, 11:15 AM   #3
subedude17
Member#: 65332
93 L seiries wagon
white
i want full time awd and something that wont **** its self and need replacing all the time
Old 06-30-2004, 11:51 AM   #4
Calebz
Member#: 54398
1980 CB400 Hawk
The FT4WD box for the EA82 is definitely not going to take a **** on a regular basis. and its a lot easier than swapping in the EJ trans.
My FT4WD trans has almost 200k miles on it.. still going strong. The EA82 just doesn't push enough power to blow it up. And those boxes are in no way fragile.
Old 06-30-2004, 11:57 AM   #5
subedude17
Member#: 65332
93 L seiries wagon
white
so my cheapest and easyest bet would be to buy a FT4WD box, and this is full time awd and and i can do a straight swap for the ea82 box???
Old 06-30-2004, 12:05 PM   #6
subedude17
Member#: 65332
93 L seiries wagon
white
ohhh lol i didnt read that properly forget the question about it being full time awd
Old 07-05-2004, 01:03 AM   #7
MilesFox
Member#: 64965
87 87 RX 95 Legacy
duplicolor, aluminum
the rx and the xt6 have full time 4wd with diff lock. when the diff is locked its like regular 4wd. unlocked you can drive on pavement with power to BOTH the front and rear. they will bolt up the same.
the rx has dual range, so u can use lo-range on the street!
you will have to use 25 spline axles for the full time tranny. doj from later models will swap on 3spd sauto turbo's axles(ea82) to get 25 splines out of a 23 spline turbo axle
MilesFox is offline   Reply With Quote
Old 07-06-2004, 12:06 AM   #8
camshaftprelube
Member#: 54415
A strange
Tercel attraction
Psst...Hey Fox...
Not to be a dick or anything, but you need some better tires...
camshaftprelube is offline   Reply With Quote
Old 07-06-2004, 01:04 AM   #9
MilesFox
Member#: 64965
87 87 RX 95 Legacy
Originally posted by camshaftprelube
Psst...Hey Fox...
that thar RX turbo with ported heads and carby block is the reason them tires are bald!
i got a nice set of wagon wheels at the junk today. pending hookup on puegots how many SETS of them do you want? hollar back, check the post on the usmb marketplace
Old 07-06-2004, 01:54 AM   #10
BritneySpears
Member#: 29495
Chapter/Region: HIIC
NOT cobb stage 2
gosu micro
rad
BritneySpears is offline   Reply With Quote
Old 07-06-2004, 09:44 AM   #11
MilesFox
Member#: 64965
87 87 RX 95 Legacy
if anyone didnt notice those are chevy 6 lug truck rims drilled out for a subaru 140 x 4 lugs, 205/55 16 camaro tires
Old 07-06-2004, 07:28 PM   #12
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
rad
Tizzle is offline   Reply With Quote
STI complete running gear Hopper Private 'For Sale' Classifieds 5 03-13-2006 07:14 AM
Re: Running gear on Gadiels 720hp sti bugeyes Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 12-28-2005 07:11 AM
Mixed Climate Trail Running Gear semabe Off-Topic 1 06-03-2005 02:50 PM
anyone tuned for running gear-mapped boost? erggy Engine Management & Tuning 0 04-17-2005 08:38 AM
'04 STi running gear into '02 wagon? alacrity024 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-23-2004 02:23 PM
