Old 06-30-2004, 11:22 AM   #1
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Default what are good ej22t compression test #s?
what is ballpark for an ej22t with SOHC 02RS heads?
how does 125+- 5ish all around sound.
to me it is good that they are all very similar. Should I take this as compression is good = engine is most likely good?
I have heard this combo runs around 8.3-4 ish to 1
I was expecting higher numbers actually more like 135 or 140.
please respond asap.
Thanks
Todd
Hitokiri is offline   Reply With Quote
Old 06-30-2004, 01:11 PM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
This combo is more like 7.6-7.8:1 and those numbers are decent.
Drac9 is offline   Reply With Quote
Old 06-30-2004, 03:58 PM   #3
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
k thanks!
Old 06-30-2004, 05:29 PM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Was the motor warmed up? Numbers can change big time when the motor is cooled off.
subiekid is offline   Reply With Quote
Old 07-01-2004, 02:17 AM   #5
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
i am not sure
I will find out
what are ballpark #'s for cooled of and warmed up?
I have a feeling those are warmed up numbers.
Todd
Old 07-01-2004, 02:51 AM   #6
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Errrrrrrr
The car was sitting for over 2 hours while I waited Definately cooled unless driving 20 feet is warming up
benjaminetanyahoo is offline   Reply With Quote
Old 07-01-2004, 08:49 PM   #7
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
ok good
Old 07-01-2004, 11:09 PM   #8
Unsung Boxer
Member#: 37196
most important thing is that each cyl is w/in 10 from the others. If you are losing compression it will most likely be in only one, maybe 2 cylinders. Chances of all 4 losing compression and being about the same is not likely.
That being said, those who dont have compression testers, who want a backyard check, do this:
Disable ignition by unplugging coil pack. Crank engine for about 5 seconds straight (car wont start). Listen for what we call, even cranking. There is not points where the engine cranks faster or slower. it should be even.
A trained ear can hear minor compression loss. Major compression loss is obvious.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 07-01-2004, 11:27 PM   #9
subiekid
Member#: 25516
-Jake
remove fuel pump fuse as well.
Old 07-02-2004, 12:09 AM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Yup, being close to each other matters more then the numbers themself.
Ya, depending on the gasket...
http://forums.nasioc.com/forums/show...ght=ej22T+ej22
What is the standard compression test values on a 2.5ltr with forged pistons tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-25-2005 03:16 AM
what is good cylinder compression on the sti? CBRDSpeedfactory Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 04-14-2005 08:50 PM
ej22t compression test #'s scubydrew Mid West Subaru Owners Club Forum -- MWSOC 1 09-15-2004 10:48 PM
What are good brake pads for my L sedan?? Suggestions?? 96Lconversion New England Impreza Club Forum -- NESIC 10 07-27-2001 08:13 AM
what are good tire pressures for autox? iBlueVirus Brakes, Steering & Suspension 7 05-05-2001 08:34 AM
