Old 02-04-2001, 10:27 AM   #1
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
Have a Nice Day? Help: MY00 shakes at idle; even after warm up?
Like stated it's a MY00. I just hit 8000 miles. At idle at any time the car shakes somewhat. Sometimes worse than others. It almost feels like a hesitation. It feels fine when driving. At 6000 miles, I changed the oil and replaced the spark plugs. I used the reccommended NGK's. I've since checked and rechecked the plug gaps and seals. Oil was Castrol syntec blend 10w30 and the filter was Mobil-1. I reset the ECU and the car idles at about 1100 rpm cold and about 500rpm warm. It doesn't feel like it's going to stall or anything, but is quite annoying and I'm kind of worried. Should I make an appointment with the dealer or this something I can fix myself (hopefully!) Please help! Thanks!
Robmat
[This message has been edited by Robmat (edited February 04, 2001).]
Robmat is offline   Reply With Quote
Old 02-04-2001, 11:52 AM   #2
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Lightbulb
Those numbers are normal. Your vibration could be a loose plug wire. I had to crank down on the plugs, more than I would like to, when I changed them, otherwise the wire would wiggle out. Check to make sure the plugs are in straight. The engine vibrates a little anyway.
Zee
Sunrise City Rider is offline   Reply With Quote
Old 02-04-2001, 01:42 PM   #3
Rez
Member#: 1958
1999 Impreza 2.5 RS
Rally Blue Pearl
Post
But one of the things that was touted to me about the boxer engine is that because it is horizontally opposed, engine vibrations are significantly less than a V-4.
Do yourself a favor, have a friend quickly and slowly rev the engine (different responses, loads etc etc) while the hood is open and see what it is physically doing. Check your engine mounts, listen for anything unusual, watch how it moves. See if you can see something physically wrong like that. You've got 8k miles on it. How hard were they?
-Rez
<IMG SRC="http://www.reverberations.com/Storage/Images/scrambles.gif" border=0>
Rez is offline   Reply With Quote
Old 02-04-2001, 02:37 PM   #4
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
Post
A moderate 8k miles. No racing or auto-x. City driving and a few short trips. Although, I do tend to be racy sometimes.
Old 02-05-2001, 09:51 AM   #5
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
Post
Still doing it...bump.
Old 02-05-2001, 03:31 PM   #6
sube151
Member#: 3184
00 Grp N Wrx STi,
+99 V6 STi,
Post
Hmm....mine does the same thing. Almost feels like a miss when its idle. Its not constant though. Once you rev it a bit, its purty smooth. You can usually feel it at the stop light.
How ruf is the "bump"?
sube151 is offline   Reply With Quote
Old 02-05-2001, 04:39 PM   #7
Dirt Man
Member#: 176
2011 Subaru Forester
Post
I've had this exact problem, actually still have it slightly. Double check your plug connections, mine came loose on #4 and fryed the ignition coil. Not fun riding to the dealers on 3 cylnders, sounds like a 2 stroke lawn mower. I've got to tighten things up this weekend and see if it helps.
Dirt Man is offline   Reply With Quote
Old 02-15-2001, 08:08 PM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
huh. My car just started doing this yesterday. I checked all the wires and they are fine.
The engine is as smooth as can be Everywhere except for idle. As soon as I hit the gas, it smooths out. Even if I hold it at 1,000rpm's with .5% Throttle angle (According to S-AFC) it is smooth.
I opened up the hood and the engine seems to be shaking about as much as it should. It's hard to tell.
If I pull a wire while it is idling, I get a really bad Misfire (Obviously). If I listen to the exhaust tone, It doesn't sound like a miss.
And Finally, When I floor it and Hit the Nitrous, It goes fine without exploding like a miss will do in a nitrous engine.
So, I have no idea what it is!
Eric
Eric SS is offline   Reply With Quote
Old 02-15-2001, 08:17 PM   #9
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
Post
Huh, maybe it's a quirk we'll just have to deal with. I'll let you know if there are any changes or fixes!
Robmat
Over rev'ng in the Cold, gone after warm-up Bonjo2 New England Impreza Club Forum -- NESIC 8 02-13-2006 12:10 AM
car wont start after warmed up?? gotawd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 12-20-2005 06:26 PM
Popping noise from the front after warmed up St3v3 Brakes, Steering & Suspension 8 08-17-2005 01:44 PM
Thick Blue Exhaust after warm-up slingshot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 05-16-2004 08:47 PM
Oil Temp. After warm-up on WRX-02 rdrandal Newbies & FAQs 6 04-27-2002 12:40 AM
