Old 02-06-2001, 09:21 AM   #1
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
Question Where is your oil temp sender?
I've got mine in the center of my oil drain plug and it's a horrible location. Does anyone else have an oil temp gauge, and if so, where is your sender installed? What kind of temps do you see at idle, cruising and if turbo'ed, under boost? Thanks!
RyanC is offline   Reply With Quote
Old 02-06-2001, 09:24 AM   #2
grimlock
Member#: 2683
2011 STi 5-Door
Post
Yup, oil drain plug replaced by oil temp sender. That's the way mine is.
Ross N.
grimlock is offline   Reply With Quote
Old 02-06-2001, 10:05 AM   #3
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Post
Yeah, I think it's a horrible location too. In the winter months, I hardly ever read anything over 60c and 50c is where the needle starts. Thats also if you're in traffic for awhile, if you're on the freeway, forget about it, the needle goes right back to it's resting position.
In summer, I've read up to 80c (maybe more, can't remember) during stop and go driving.
Boostup! is offline   Reply With Quote
Old 02-06-2001, 10:22 AM   #4
Scoober01
Member#: 3649
2001 Impreza 2.5 RS
Blue Ridge Pearl-Red acc
Post
BUMP...
Scoober01 is offline   Reply With Quote
Old 02-06-2001, 10:27 AM   #5
Jay_UK
Member#: 296
Post
Howdy..
I have mine mounted in the side of the oil pan/sump.
It doesnt get caught/knocked by anything..and it is sheltered from all the winter snow and rain...
But it does mean you have to remove your sump and have a threaded boss weld on.
J.
Jay_UK is offline   Reply With Quote
Old 02-06-2001, 10:43 AM   #6
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Post
Since December (with the cold weather)
Installed in the same location.
My range is 130-160F.
On the highway its closer to 130F.
Higher temps during idling.
After driving around town and parking, the highest Ive seen it this winter (today)is 180F (and thats with the car not running)
Rich L is offline   Reply With Quote
Old 02-06-2001, 03:25 PM   #7
RyanC
Member#: 2634
Tornado Red
Talking
Does Autometer make a dual oil pressure/temp sender that could go where Edwin has his? Also, what about the little plugs on the top of the head, where my oil feed line comes from. I think there is another one, maybe that can be opened up? I ought to call Dave and Andy and ask... I absolutely hate reading oil temps from a location that has no oil on it when the motor is running
Old 02-06-2001, 03:29 PM   #8
Jay_UK
Member#: 296
Post
There are one or two "plugs" in the block... these are to seal off machine access points for when they machine the oil galleries...
I suppose these could be used.. but again I still prefer the sump location
J.
Old 02-06-2001, 04:08 PM   #9
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Question
To repeat Ryan's followup:
Jay, do you see oil temps you believe to be accurate with the sender mounted on the side of the oil pan? What range do you see when pushing the car hard?
Jon Bogert is offline   Reply With Quote
Old 02-07-2001, 12:05 AM   #10
RyanC
Member#: 2634
Tornado Red
Thumbs down
You know those temps have got to be bogus, right? I barely break 125 on the highway, which can't be right! My old car, which admittedly ran hot, would be about 180f when the car was warm and cruising would see 220-245. I don't expect the same in the RS but I'd expect more than the 160f max that I've seen.
Jay, how big of a pain is it to weld a boss on there, and what temps do you see? I was thinking about putting the sender in-line with my oil return line from the turbo, but I don't want to interrupt the oil flow, either.
Old 02-07-2001, 12:11 AM   #11
efoo
Member#: 80
Post
underneath the alternator on the block is the factory oil temp sender. i stuck a T in there for my oil pressure sender - i don't see why you couldn't put your oil temp sender there too. it's a tight fit though, so be warned - wear gloves or be prepared to nurse your knuckles for a few days.
-Edwin
efoo is offline   Reply With Quote
Old 02-07-2001, 12:36 AM   #12
Jay_UK
Member#: 296
Post
Hi guys...
Its a awkward job.. the sump isnt too easy to remove
Efoo..the connection under the alternater is the oil pressure pickup.. not temp.
I didnt want to place the sensor in an oil feed/return... I prefered it somewhere where there was plenty of oil... and that wasnt forced by so much..
J.
Old 02-07-2001, 01:34 AM   #13
Jay_UK
Member#: 296
Post
Sorry guys.. I missed that part of the post.. lol
Normal driving I see around 80-90 degrees (My oil cooler is thermostatically controlled for that)
Underhard continous abuse... I can get upto about 110'ish.
The above temps are in degrees C.
J.
Old 02-07-2001, 06:32 AM   #14
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
Post
Hmmm, that sounds pretty accurate to me--that's where I'll mount mine.
Old 02-07-2001, 09:56 AM   #15
IMPBOY
Member#: 65
Post
Jay or RyanC,
Where are these "one or two" plugs on the block? Are you guys talking about two huge plugs near the oil filter where the OEM oil cooler mounts?
Do you guys know where I can put the water temp sensor?
IMPBOY is offline   Reply With Quote
Old 02-08-2001, 12:37 AM   #16
RyanC
Member#: 2634
Tornado Red
Post
IIRC they are on top of the block, the one I'm using for an oil feed to the turbo is to the left of the TB, as you look at the engine from the front of the car. Not sure on the water temp sender, I suppose you could put it on the line going from the radiator to the block? Just thinking out loud, I don't really know if that's a good spot or not.
What is your Oil Temp? Stames_wiltz Rocky Mountains Impreza Club Forum -- RMIC 14 05-03-2010 01:03 PM
Oil temp sender davemade Electrical & Lighting 8 03-01-2004 01:31 PM
Oil Temp Sender ... Black 2002 WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-08-2002 11:59 AM
Autometer UltraLite 4341 Oil Temp sender to oil pan plug adapter? Slappie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-22-2002 02:22 PM
What is your Oil Temp? cantex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-12-2002 10:17 PM
